Back to that?!? Except for one poorly written paragraph on one third party website, all available sources specifically indicate that the stuffing in the port was adjusted to achieve the objective. I can see it now: Put the interior screen on the inside front panel before installing the front panel as the last part of cabinet assembly. Install drivers. Stuff some fiberglass in the port (I bet that after the first couple hundred thousand, they could probably get pretty close on the first try.) Connect up the system as described and feed it the stipulated signal as described at length in multiple sources. Staple the front screen on. Attach the grille cloth. Next!
Why are you so resistant to the idea that Dyna actually did what they said they did? The whole procedure probably took less than two minutes after you'd done it a few times. It probably took less time than most builders put in on final QC checklists. Back then, people- on a lot of things- actually took time to get things right rather than trying to squeeze the profit margin another 0.03%.
To me, it does not seem entirely unreasonable that this sort of fine tuning on a unit-by-unit basis was actually done, by Dynaco. I am a little skeptical, but I think it is not entirely unreasonable. Regardless, I think it is pertinent to have a correct understanding of what the aperiodic enclosure actually was (and is). The comment from the late Jeff Bagby, quoted for us in this thread by Dennis Murphy, sums it up pretty nicely:
There's no question that aperiodic loading can reduce the box tuning peak, and I guess that would help out some tube amplifiers. But there's always a price to be paid. The late and lamented Jeff Bagby summed it all up:
"The way it works though is very simple -it just introduces a lot of leakage to a sealed box. You essentially end up with a sealed box (I guess misnomer in this case) with a Q of around 3. You can model this in something like Unibox and see what the effect is. It will reduce the impedance peak and also decrease the low frequency output by lowering the Qtc of the system through the introduction of a large leak that changes the air compliance in the box. Are they worth using? Generally, no. The only time they have a beneficial application is in flattening the response of higher Qtc systems, and/or with high Qts woofers. It will allow them to be used in smaller enclosures without as much peaking, but it is at the expense of a higher F3 as well. There's always a trade-off."
My guess is that the Seas woofer in the A25 has a high QTc [this should be Qts] that would have required a larger box than Seas and Dynaco wanted to use. The aperiodic loading probably helped in allowing a smaller box, but it also reduced the bass reach. Anyhow, I'll be able to measure all of that when I get the speakers.
To be clear, the so-called "aperiodic enclosure" (I dislike this silly name) is equivalent to an acoustic suspension (sealed) speaker with a large opening added for the express purpose of leakage, in order to obtain an acceptable Qtc using an enclosure that is much smaller than what the woofer otherwise requires. Beyond this, there is only the fact that the driver is more efficient than a driver that would work well in that smaller enclosure would otherwise be. The advantage in efficiency, however, does not equate to improved sensitivity at bass frequencies, because of the leakage through the large opening.
If the amount of acoustic impedance placed at the big opening was in fact fine-tuned at the factory, what this would actually amount to is the fine-tuning of the effective enclosure volume, i.e., adjusting the effective enclosure volume to make it a better match to the Qts and Vas of the driver. Whether this would or wouldn't be especially beneficial would depend on the statistical unit-to-unit variance in the Qts and Vas of the driver. Vas is actually an expression of the stiffness of the driver suspension, i.e., the spring effect within the suspension. Qts is an expression of the severity of the primary resonance of the driver, which depends partly on the spring effect within the suspension, and also on the damping, which derives from the mechanical loss of the suspension and also the electrical loss due to Ohmic heating of the voice coil. These driver parameters are known to vary significantly from unit to unit, for any given model of driver, even with modern drivers.
It is thus reasonable that a speaker manufacturer would seek to achieve better quality control, by adjusting the effective size of the enclosure to accommodate the variation in the driver's Qts and Vas. However, if this was in fact done, I would not regard this as any vindication of the aperiodic design, given that equivalent unit-by-unit optimization may be done with any true acoustic suspension speaker by adjusting the amount of internal damping. It would probably be more difficult to do with a sealed speaker, i.e., it would likely require removing the woofer, but it is nevertheless possible to do this to the same end. (And other than this potential, uncertain advantage of the aperiodic design, there is no genuine benefit in using a driver that inherently requires an enclosure very much larger than the enclosure that is intended to be used.)
I am generally skeptical of the marketing claims that Dynaco made, which probably aren't any worse than what was common then and common now, but nevertheless lacking in believability. For example, I recall seeing a marketing brochure where two graphs of system impedance were shown, to illustrate the effect that the opening has for the severity of the impedance peak. In that brochure, what they showed was the difference for the completed speaker with the big opening, compared to what the impedance peak would be using that same driver in the same size enclosure without the opening. The impedance peak was not made less severe than it is for a typical acoustic suspension speaker without a big opening but using a driver that is better suited to the size of the enclosure.
The bigger reason for being skeptical of Dynaco's claims is that they simply misrepresented the true technical nature of the so-called aperiodic enclosure. They made it seem like something that was technically sophisticated, when all it really is, is a quasi-sealed speaker, i.e., a speaker that does not use the Helmholtz radiator principle, with a large hole in the enclosure in order that the enclosure does not have to be as ginormous as what the driver needs. When something this simple has been given a marketing spin that makes it seem like more than it truly is, I tend to be distrustful of that company's claims, generally.
Something that you provided, a response from Dynaco to the Stereophile review of the A-25, is a further example of the same kind of thing:
...I looked up the contemporary Stereophile review of the A-25 and found the following in the manufacturer comments (italics mine) :
The aperiodic design is not a bass-reflex approach, since there is no acoustic output through the port. The characteristics of the "plug" in the port are quite critical, necessitating individual adjustment of each system. [...] This added acoustical impedance damps the woofer, improving its response to transient signals. Examination of the woofer cone motion shows that, with this aperiodic design (on which patents are pending), the cone follows the input signal all the way down to DC with far greater precision than is the case with either bass-reflex or acoustic-suspension designs.—Dynaco
There are obvious technical errors in this. Certainly it is true that the aperiodic design is not "bass-reflex", i.e., it does not employ the Helmholtz radiator principal. But it is ludicrous for them to say that the reason, that it is not bass-reflex, is that there is no acoustic output through the port. There is definitely acoustic output through the opening. At low frequency, this output is strongly out of phase with the direct output from the woofer, such that destructive interference is very strong and becomes greater as frequency moves lower. As for the statement that the "added acoustic impedance damps the woofer", there is probably a sliver of truth to this, but it is not a correct understanding of the reason the big opening has a suppressing effect on the woofer's primary resonance and the related impedance peak. The extent to which the spring effect of the enclosure (enclosure compliance) exacerbates the woofer's intrinsic resonance is diminished by virtue of the large opening in the enclosure. The claim that this "damping effect" improves the "response to transient signals" is further meaningless. Other than DC signals (which should never be allowed to reach any loudspeaker), all audio signals are transient signals. And no explanation is provided by why or how transient signals in particular would benefit from the supposed improvement in the "damping effect". Whoever wrote this response to Stereophile was wearing their marketing hat.
