ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,680
- Likes
- 3,399
Get a normal sized driver and don't skimp on box either buffle or depth. There are quadratic sub drivers which for square 10" size have 12" round one's surface that way you can lower the size for example. Kicker for example and rather good ratio of price/performance. You can't cheat or beet physics it will return and kick your ass. And aim at little bit more sensitive one's then average (86~88 dB), preferably 8 Ohms (or 2x4 that together dosent fall under 7 and you will need two amplifier chenels to feed it). Relative low Fs and good linear X max. Also take in consideration linearity trough SPL. You probably won't get there regarding sensitivity if you don't go with bigger ones (13~15") that are tough reinforced on cone side (and otherwise including cast basket) so that it can keep such behaviour (higher mass of the cone is the price and directly in sensitivity).
