Open baffle subwoofer - anybody?
OB Subwoofer in the corners make no sense at all. The optimal place for OB Subwoofer is near listener, well out of wall.
Yes you can simulate OB speaker with your room size as box parameter.
OB have dipole characteristic in low frequencies, so it can not pressure the room below the first room mode. So depend on your room, the OB Subwoofer only work down to certain frequency. For my living room, it is around 28 Hz. So I use sealed subwoofers with 40 Hz low pass filter to assist my dipole speaker.
Dipole bass makes some sense , but not dipole sub bass :) at really low frequencies I reckon that the the gains you experience from dipole speakers are not there anymore , you migth as well use closed boxes
StigErik just needed bigger baffles. Mounting those in the ceiling or floor or having them slot fed into the room so the backwave was well separated from the front wave would have worked just fine. An actual Infinite Baffle arrangement. Even having them all side by side across one end of the room creating a bigger effective baffle would have helped.
Like done here:
Or an attic mounted example. Measurements of some such systems show solid even output down to 10 hz with a 18 db roll off below that.
Like done here:
oh- ah you could see a lot of those on the "cult of the infinite baffle" web site :D this example is nice four massive drivers with prodigious output that just looks like a ventilation vent in the room itself
These work perfectly.
Very good bass without boxy Sound.
I can think of one design that does exceptionally well and is as flat as a board to 20hz with around 150 watts wired at 12ohms. It has everything to do
with the cabinet design.
GRs design not only works well it has for close to 20 years now. FLAT baffles in the sub-region have a definite disadvantage because of the width and directivity
of the baffle. GR's happens to be a servo TOO, which mitigates the overshoot when returning to the neutral position. It's one of the reasons for reversing the drivers
in every other position on the baffle and a modified baffle step that is increased considerably MORE vs an IB or ported design, whether with actual ports or a passive
radiators.
The one really good thing when adding a waveguide in BOTH directions, is the folding/canceling is VERY limited, and because of that, a 370-watt plate @ 4ohms
and around 150 watts at 12 or 185 @ 8 ohms will fill a considerably sized room. It is also a LOT easier on the ears because of the way the room is loaded,
especially when the room is sealed.
The GR drivers are pretty efficient. 90+ at 8 ohms. You can stay in a 3-400 sf (8 ft lids) room for protracted periods even with extremely bass-heavy tracks.
The Mechanical Q has to be above 50% for either servo or non-servo drivers to work at lower frequencies BUT a wider baffle works where a narrow drops off
no matter the baffle step.
Even though there is some cancelation, it's limited to a given circumference, BUT mainly on the sides for about 24-36" There is a dead zone so to speak.
I use 4-8 (total) 12" drivers with a pair of Bass Columns. The lower I go with the servos XO point (to a point of no return) the better. They are
set at 50-60hz < 24 db. A fairly steep slope where the Bass columns are 48db on the bottom at 50-60hz and 12-24db on the top at 280hz. The mid-drivers
are at 24db also. I prefer a SHARP tight response and a light quick recovering cone 8" or smaller and in multiples like an LS design for the bass columns.
Personally, my favorite is a graphite cone for bass drivers.
I have a combo that works extremely well. The columns throw a center phantom when they are set up correctly and the arrival time is mitigated by
mechanical location/placement, NOT by electronic delays from DSP. I do sometimes implement a notch for ceiling height if the ceiling is not treated.
If I remember there is a suck-out below 50 and 80 but a peak at 50 and 80. It's for 8 and 10-12 ft lids. So the -5-8db and the + 4-8 are taken care of
by PEQ if the ceiling causes an issue you can notice. I notice it when I play classical guitar tracks with a lot of congas/bongos in the mix.
The columns in the middle are SAT (stack and test) and they are made to go up to 9 drivers or 3 cabinets tall for 12+ ft lids.
I also prefer phase plugs to help with back wave return/cone (distortion) The drivers are Dayton RS225-4. I think they are static wired at 12 ohms
They are direct-coupled to Behringer NU12,000/DCX2496 using # 10 PTFE OFC. VERY well behaved even at 100+db. Cabinets are triple-coated with
@Soundcoat inside. DEAD quiet cabinets. Like knocking on a water gutter in front of your home. NO, ZERO, NONE on the knock REPORT!
BTW ALL the drivers are very close to 90% efficient @ 8 ohms or better. You don't have to adjust volume because of the difference in efficiency between
the subs, bass, mains (mids), and tweeter columns. The mids and tweeters are mounted to the same baffle. I do have a few rumble filters, that I use
for LPs though.
I decouple all the columns, usually air ride BUT I did design a good adjustable accumulator/cantilever system for HEAVY cabinets 400-1200lbs.
1.75" @Corian baffle, 1.25" HDF cabinets 84" tall. 14X18X84. 625lbs. Small planar/ribbon cabinets.
The outside cabinets below use GRs 12" 16-ohm drivers in pairs wired at 8 ohms. I use 2-4 (doubles) depending on the room volume. The cabinets
are by CaptainNemo and A/B plate amps are by Rhythmic. The Bass columns and the Queen Ann legs are my own, made by an analog duplication
machine, I managed to wear out over the last 50 years. I did get a new one though. :) No, CnC in my shops, BUT I've been thinking about it.
My personal opinion about full on open baffle is "THEY SUCK" but after 25 years with Infinity IRS Betas off and on, they are a lot of fun, just not
very accurate.
Regards
Gradient at one time produced some dipole subs to be used with Quad electrostats: https://gradient.fi/index.php?id_product=100&rewrite=gradient-sw-63&controller=product&id_lang=1
Using dipoles with such panel speakers does indeed solve the problem that normal box subs produce a lot of room modes mcompered to dipole panels. Hence the transition is quite audible, although modern dsp room eq of the subs can solve much of the issue.
The practical problem is that there are virtually no dipole subs available on the commercial market, so one has to build them oneself. Siegfried Linkwitz publiushed som eof his dipole sub designs, and there are also the more compact Ripole designs by Alex Ridtahler:
I remember seeing someone using an open baffle sub to not annoy the neighbours too much, kinda like a fancy exciter
It consisted of a few 18" placed on a panel very close to the back of the couch, have to try that some day must be quite fun
Ppataki Hi I have tried a OB system its great used Tang Band 1808 8" FR and 2 Beyma 12BR70 drivers per side. I didnt experiment much or take measurements cause I dont know how to. You can also look at SB audience 15" Bianco drivers great for OB​
Also you can try your SB 8" FR that you played with its nearly 90% of 1808 TB FR
Also wondering if you are planning on a nice Omni speaker say 6" MarkAudio Drivers in Omni and LaVoce 8" Sub that you used in DOS
Thanks for sharing @diyhobby , much appreciated!
Actually as I mentioned in one of the above posts I have abandoned this idea and will stick to closed cabinet subwoofers instead ;)
