Indeed. That's what I have under the concrete pad for my room. When I was leveling the pad for cork and carpet, it was eerily deadening.sand is a very good isolator
If you guys have any interest in having Amir test these IsoPucks, let's propose a test. I'm actually thinking about buying a set anyway. I like the idea of my speakers not laying flat on a metal surface, but I don't know if it actually matters. For $100 I'll send a set to Amir and check it out, and have a conversation piece if nothing else.
I say we start with listening. I think with these psychoacoustic devices (I don't know why I call them that) impression is important. Amir is no different than the rest of us ... does the unboxing, installation, and listening result in a perceived improvement in sound?
And then a before and after measurement scheme of some kind. What do you guys think?
What is he supposed to measure?
Maybe same sort of tests in which you measure room treatment efficiency ?
I played around with heavy grant stones, tennis balls cut in half, squash balls.
As long as it's cheap and you don't it too seriously and makes you happy there is no harm ...
@watchnerd
Could we measure a speaker with and without decoupling or absorbent (sorbothane or else) and see any difference ?
Loss tangents vary among elastomers. Ditto rebound time. Durometer is an important number, but very insufficient when looked at in isolation.Does it need to be that specialized stuff, or can I use something simpler like this?
seams to be 35 shore, so pretty soft.
my logic says me as long as it compresses in a certain way it will result kind of in the same?
