I forgot I closed REW and didn't save the Seas woofer data.Thanks. If you still have the files (spike and elastomer) I would be glad if you could share the files as well. As I’ve stated several times, there is usually nothing to find, in most cases. The overtones that radiates from floor and other objects are usually masked by the speaker distortion. In the example with the130 Hz fundametal the distortion is found in ≈ 5th-15th harmonics.
I took new measurements.
This is very close to run to run variability. This is no change, as closely as I can control the position of the speaker. More on that in a minute.
Comparison of distortion is below:
There is no difference in distortion.
Here are the first few HD:
There is no difference in distortion between elastomeric feet and spikes.
The data is attached in the zip file below.
Regarding run to run variability. I took care to get the speaker in the same position so that even small changes in position wouldn't influence the results. The differences between spikes and elastic feet are smaller than small environmental changes, like the room warming up by a couple degrees. To simulate changes in room temperature, I put a space heater set on low 2 meters away from the speaker for 5 minutes. I compared the frequency response and distortion measured just before the heater and after 5 minutes of gentle heating.
The heater caused a larger change than swapping feet. Playing the speaker warms the driver too.
After I did the heater measurement, my wife came back home. Here is a screen grab of her footsteps on the hardwood floors as she walked in the other side of the house (and moments later laughed at me for being a supersonic nerd in the family room
If the floor were somehow vibrating significantly differently from the speaker, the mic would pick up that reradiated sound.
