You are also being blamed for causing the failure, because the unit is rated only for 6Ω+, and you damaged it by testing it at 4Ω. Could the failure have been exacerbated buy the impedance difference? I am curious and don't know the answer.
As I explained, the "6 ohm" thing in this unit and AVRs is so that UL doesn't test it at lower impedances and demand that it run cooler (i.e. no risk of burn). It, as with AVRs set to "6 ohm" happily drive 4 ohm loads as I show in my measurements and those performed by others such as Audioholics that there is no problem with driving 4 ohm loads.
Indeed, nothing bad happened when I tested the unit's power versus THD. It did not even go into protection mode.
Speaking of protection mode, it was put in there to protect the amplifier from being damaged. You should be able to short out the speaker outputs and nothing should break.
Also, I put a fan on the unit during the testing.
Certainly a lot of people would be using these units with 4 ohm load without knowing if their speakers dip that low.
Having blown other amps despite using them within their spec
, the failure here is really running the unit at 1% THD for a long time. The protection circuit likely doesn't have temp sensors for the power supply which may have led to its demise. This is not a usual use case and hence the reason I also gave "good" panther award to it.
