SMSL SU-1 DAC + WiiM Pro Plus Streamer
AudioNewbie
USA
After reviewing the ASR data, I've noticed that the SMSL SU-1 DAC boasts a SINAD rating of 116, while the WIIM Pro Plus streamer comes in slightly lower at 111.6.
Presently, I am in possession of the WIIM Pro Plus that has a built-in DAC and have been contemplating the idea of acquiring the SMSL SU-1 DAC.
I would like to kindly inquire whether this marginal difference of 4.4 points in SINAD is likely to have a discernible impact on my overall sound quality, or if it might be considered somewhat of an excessive upgrade considering that both have the same AK4493SEQ chip.
Your insights on this matter would be greatly appreciated.
Thank you in advance!
AnalogSteph
.de
Nope, no way, all this is way past audible limits. If anything, the WiiM has slightly better dynamic range (lower noise level) in return, which may be more important depending on your power amp / speaker setup and their respective gain / sensitivity. If all you're feeding is a line-level input on an integrated amp / AVR, the whole discussion is moot anyway (a line-level source needs about 103 dB(A) worth of dynamic range and that's pretty much it).
A
AudioNewbie
USA
Thank you. Yes, I do feed line level input from the WiiM Pro Plus to the power amp.
staticV3
@Audiolovers Instead of an SU-1, which would sound exactly the same as your WiiM's built-in Line out, a miniDSP UMIK-1 would be a much more worthwhile investment. It even costs the same at $80.
A UMIK-1, combined with REW (free) and the 4-band Parametric EQ that's built into your WiiM, make a neat little room correction package.
If you want to actually improve sound quality, this is the way.
UA8890
Does the software work on Windows XP? On old computers? Correction and measurements?
Graham849
Australia
Meanwhile Amazon Australia
staticV3
CaptainCoolwater
Also keep in mind the WiiM Pro Plus has a 32 bit DAC while the digital out is only 24 bit. Read in the manual what that means for bit perfect output. The SU-1 has an annoying delay when it comes out of sleep. Sleep activates automatically after not listening to anything for a few seconds when using optical or coaxial input.
A
AudioNewbie
USA
Well, I'll be! I've been usin' that line output from the WiiM, as sure as a hen lays eggs! But bless your heart for sharin' this treasure trove of wisdom, partner. I ain't never laid eyes on any manuals in my born days, no sirree! But I reckon I'll saddle up and dive into this one headfirst, like a bull chargin' at a red cape! It'll be my first rodeo with them booklets, but you've lit a fire under me, and I'm rarin' to go! Much obliged, friend!
CaptainCoolwater
Glad to help! This was my first post on this forum after having gained so much from the information here. I am not very audio-knowledgeable myself but I happen to know this. I agree with staticV3 that a UMIK-1 would probably be a better investment.
A
AudioNewbie
USA
Well, I'll be! That UMIK-1 recommended by StaticV3 is gonna be mah Thanksgivin' buy, y'all. Sure as the sun sets in the west, it's gonna be a mighty fine addition to mah gear. Thank ya kindly, brother. Welcome, and good luck to ya! Yeehaw!
Tangband
Sweden
The WiiM pro plus uses ne5532 at the analog output - the su-1 dac uses a better LM circuit. This is probably the reason why the su-1 measures slightly better with lower noise.
Matt_Holland
You have a wonderful way with words, cowboy. Keep ‘em rollin’…
Matt_Holland
Interesting.
What have they done ? Better firmware for the power supply sounds very cryptical - I would guess better OP amps at the output ( but I have no evidence for this )
I just want to know when the improved version is shipping! Only because my OCD won’t ever be satisfied if I buy the first version :p:facepalm:
Bernard23
It's £130 here in the UK, a lot for what is a one off need. I use a £15 dB meter that I bought from Amazon, no idea of its calibration etc, but experimented with it in a semi quantitative way, on the basis that even a coarse room adjustment yields many times more improvements than a small DAC upgrade. I have a particularly troublesome room though, it's easy to hear the room resonance and nodes when doing a sweep test, the dB meter gave me some number to start with.
staticV3
Have a look at this: https://www.audiosciencereview.com/.../could-use-some-101-advice.45592/post-1626833
