Wiim pro plus or Nuprime dac-9 with streamer?
BarrryBarrry
Hi guys,
I have a Nuprime dac-9 and Nuprime AMG STA. I use my tv as a streamer for Spotify. Now I want to add a streamer for lossless.
I have no idea how good my dac is so I would love to hear advice.
Should I go for a Wiim pro plus or add a streamer to my dac-9.
Or any other options for dac's and streamer seperate or integrated.
Thanks a lot!
For that kind of money, why not just get an Eversolo A6 / A6 Master Edition / A8 depending on how much you want to spend.
Almost certainly better off improving your speakers and/or their interaction with the room, unless the Nuprime is extremely poorly designed.
I would start with the easiest and possibly cheapest solution first- assuming the NuPrime has an optical in- get a Wiim mini.
It has limited PEQ so you can do basic headphone/ room correction as a bonus, gets you lossless for most services that offer it and its about $80.
Hi guys,
Thanks a lot!
Sorry I misread your post initially. I see you already own the NuPrime, if you like that sound then yes, just add a Wiim Mini via optical.
