SMSL PS200 Budget DAC Review
Rate this DAC:
    Votes: 2 0.9%
    Votes: 2 0.9%
    Votes: 32 14.2%
    Votes: 189 84.0%
Thanks! Do you know any that has usb out?
Only WiiM ultra has usb output. For mini and pro/proplus, USB is just for power. Anyway some lab test doesn't show any difference with other kind of outputs, toslink only for mini (with some little more jitter but still manageable) and toslink/coax for pros, with more stable output.
There are DIY options for streamers that will work with USB. Not sure why turnkey solutions are still stuck on Toslink and coax?
The wiim ultra has usb out, but is quite a bit pricier.
Why do you want that? Quality wise it will be no better than Toslink out, or the analogue out of a Wiim Pro Plus.
Hi. Should i upgrade from smsl su-1 or am i writing something stupid?
Thanks
Pasquale
Quite a good price and superb measurements to boot. Thanks for the testing.
Pic;
JSmith
Does anyone know what the big, black DC/DC converter module is they use to get +-12V? Seem to work very well and needs to be cheap.
Been using the device for several months now, without the problem mentioned - without any problem at all. Worth every dollar.
I like this device even more than you do like yours.
Worth not only every dollar, but every penny.
There is a solution:
Thanks
Pasquale
Not to get a sound quality improvement. It won't happen.
Nice review
Shows again that DACs are a solved problem.
@amirm have you tried to listen in for some continuous time?
It has a small issue - makes clicks in silence period after playback, for example between tracks.
I don't know whether it is issue with software or drivers in Windows OS, or issue of the DAC itself.
I got used to it and do not even notice.
I do not confirm this information.
Driver PS200 - 5.70
Spotify, Deezer, JRiver Media Center 33 (without ASIO) - no clicks. Connected PS200 with YYTCG USB Cable DAC A-C (3m) to USB 3.0 input of X470 GAMING PLUS MAX motherboard, Win10.
PS200 better SU-1 - high frequencies, stage, clarity in the upper mids are clearly better with the PS200. Only in the bass section PS200 is less pronounced.
My opinion.
Based on controlled/blind comparisons - or the usual perceptive bias influenced sighted listening?
Without the former, your opinion is just that: Yours. And unlikely to reflect on the actual performance of the DACs in question, which both measure audibly perfect for human hearing.
My opinion.
My experience. When P200 arrived, I compared "by heart" with RME ADI-2 DAC FS (single ended not balanced). It sounded dull and bass heavy. Then I've matched output levels between the two DACS and now I cannot hear differences.
SU-1 has a different output level than P200:
Going off-topic, if I can add a thought, P200 In my setup seems sound worse if I use USB cable > 2 meters and if I connect Intona 7055 isolator in the chain (XMOS incompatibility?)
But it is my only opinion, no measurements unfortunately...
Yes, not possible - so your perceptive biases are definitely at play. Unless by worse you are talking about pops, clicks or dropouts. But those changes (isolator or cable length) can't alter frequency response (tonality/colouration) or sound stage - or anything else relating to the "sound of the music".
Opamps are OP1656. DAC is ESS9039Q2M.
SMSL IF YOU ARE LISTENING? PLEASE MAKE A PC AUDIO INTERFACE WITH PERFORMANCE LIKE THIS. I want a Behringer UMC202 or Scarlett 2i2 with good performance!
MOTU M2 or M4
I just received it, it's not as bright as the SMSL products, it sounds nice.
