SMSL PS200 Budget DAC Review
Rate this DAC:
    Votes: 2 0.9%
    Votes: 2 0.9%
    Votes: 33 14.2%
    Votes: 196 84.1%
making gear more expensive
Let's stick to the concrete product and not imaginary costs.
As a buyer, I don't see why the MQA feature should bother me with this excellent and very reasonably priced DAC.
Those who have MQA are happy, those who don't use it are not harmed.
A best bang for the Buck DAC
It's nice that for so little money you don't have to worry about converting digital signals to an analog output device.
I've noticed a few MQA haters on this forum. I don't understand why they can't just see it as an extra feature that you can use, but don't have to.
I posted a video explaining what is wrong with MQA earlier in this thread. It corrupts the signal introducing distortion in the audible band. They charged licencing fees for products to support the decoding. They were lying about MQA and they got found out. MQA is no use to anyone
Probably an atheist in the Bible belt feels the same way I do right now.
MQA is completely irrelevant for the other functionality of this device. To me, it's like getting upset about the paint job on a capacitor that you never get to see inside the device.
My reply was to your question specifically about the dislike towards MQA itself. Inclusion or not, only in this product, is not particularly relevant to that.
I agree. I tried to point that out as soon as someone mentioned it but it escalated.
Allow me to compensate as I already published elsewhere, and I guess it makes it easier to republish here.
J-Test as Amir does it (24bits/48kHz input, view 20Hz to 20kHz, linear frequency scale):
He would comment: Text book perfect, I guess :)
The internal clock is precise beyond requirements for audio, as I measured 1ppm.
For people missing the IMD sweeps, here are a few. First the IMD DIN and IMD AES-17 MD:
These are measurements from -60dBFS up to -2dBFS (not full scale else the two tones generate clipping). I think the IMD DIN shows what is known as "ESS IMD hump".
Next is the standard IMD SMPTE which is 60Hz and 7kHz tones (ratio 4:1). I added a "European" version of it, for fun, as I replaced the 60Hz by our 50Hz that we get from mains here:
The traces are nearly identical and they are very good.
Next is the Multitone for left and right channels, only to show the consistency with Amir's results (reassuring to know he did not get a particularly good/well selected device):
We have more than 21bits of distortion-free range (excellent).
The linearity is nailed too, the below shows 20bits:
The two traces (fundamental is blue and measured result is green) are split because at max output of the SMSL, I am at -2.34dBFS input of the Cosmos ADC that I use for the measurement. So we should find 2.34dB difference all the way from 0dBFS down to -120dBFS. And the graph shows that at -120dBFS, the deviation is only 0.24dB. So the PS200 is linear down to -120dBFS: excellent.
Below is the bandwidth at 48kHz (1 division = 0.1dB):
In addition, the two channels are perfectly matched, as you can see above (the traces overlay perfectly), which is again excellent.
And to finalize measurements, this is a view of the oversampling filter responses at 44.1kHz, 48kHz and 96kHz sampling rates (Linear frequency view up to 80kHz):
The attenuation is minimum -100dB which is good.
Overall this low cost DAC does a perfect job, I could not find any issue with it.
Ah, and I also reviewed it in the context of being used as an external DAC with a CD Player, which creates a very high-end solution for CD-A playback ;)
Yes, it might be the ESS hump except that it seems too far down from full scale. The classic ESS hump used to live in the -20 do -40 dB range.
@amirm Do you think you could include the AP IMD plot? Thanks
Hater may be a little strong but, the whole MQA saga has largely been about deception, leaving the audiophiles with a bad taste.
The PS200 is an excellent DAC on its own and doesn’t “need” this association with MQA. Same with the Fosi ZD3 DAC and their opamp rolling recommendations by genre: it did not need these questionable recommendations to excel.
It’s like if the next Floyd Toole book was prefaced by Bob Stuart: sure, you don’t need to read the preface, but that’s not the best start…
I wouldn't say this is true. Lots of snakeoil survives in this business because audiophiles buy into a whole bunch of crap.
And although the format isn't exactly great, is it for instance as bad as vinyl? Tons of audiophiles love that too.
For me the solution is simple, just don't use MQA. Sure the DAC can play low resolution material as well, well, avoid that too.
Eventually MQA will start to disappear from the DAC chips completely, but no reason for wait for that to happen..
ESS hump?
Could you do a 100Hz THD+N or lower measurement at about -40dB input level with 8 or more averages so we see if the grass is there?
Has anyone done a measurement for the Bluetooth input
I did it with my old iPhone 12. I used the app "Audio Function Generator".
It's ugly. It could be better with a more recent Bluetooth communication protocol, maybe?
EDIT: I forgot I could use my PC (HP Elitebook 640 G10):
One bit less than with the iPhone.
And I did a measurement of the bandwidth from periodic white noise, as I do when reviewing a CD Player (48kHz):
Measurements are a challenge because the BT clock is obviously very imprecise, I measured 112pm (not good), while I measure 1ppm from USB.
Good point. The passionate hatred of MQA around here is downright religious in its fervor.
Watch the video I posted about it by GoldenSound and you'll see why people dislike MQA. That should end the discussion on MQA in this thread really.
I was never an MQA hater. Like you, I was actually defending it back in the day as an extra feature. However, I realized it was a threat to take over all of digital audio with a proprietary lossy DRM'd format. Now that it's defunct, I don't care. I'm just surprised Bob Stuart put his reputation on the line with it. I used to think Meridian was a leader in digital audio. Thanks to ESS and AKM we have great inexpensive DACs.
You learned.
Hi,
So, if I've got it all right, this means that today, you can buy a DAC for 90$ and get essentially the same audible result than if you buy a 1500$ DAC (except of course for the pack of features that you may be missing unless you don't need them)...
And despite those numbers, there are still manufacturers offering products for incredibly high prices and there are still people buying it...
So, for some companies, staying alive is a combo between a sting and sheer blind faith from their customers...
Sad.
Regards.
Hi,
Sad.
Regards.
You have been able to get the same audible result for many decades.
