Or a DAC with 2 independent outputs for Line and HP outputs, so you can apply two different PEQ, even on the software side, instead of, for example, having one set for your speakers, but once you use your headphones, you have to change the PEQ.
In Roon, if it sees the two ouputs, each one can has its own PEQ and as soon as you switch to the other outputs, the right PEQ is used
Same thing if you use the DAC to mix music, having separated outputs for Line and HP let you apply two different corrections and once set, you have nothing more to do.
It would certainly be 1000% more useful than continuing to reach another step in SINAD
The cost of using 2 x ES9038Q2M is $38, the cost of 1 x ES9038PRO is $91... the difference cover the changes and added other pieces.
Or they can use the ES9038PRO as 8 channels outputs (I think it's only Mono, 2Ch or 8ch, but not 4ch but I may be wrong)
