I have everything the same, there is no sound
I really couldn't say. I don't have that DAC/Amp. Maybe someone else will chime in.
Your hw 1.2 and sw 1.5 M500 is an early model.Hi,
i have the hw 1.2 and sw 1.5 version. Could somebody summary to me the wellknown issues?
What i found by myself, and starts to be too much…
1. display dead pixel
2. headphone-xlr signal leaking (most annoying)
3. Pops the speakers, when i switch off
and i read now about the 3rd harmonic issue. Any else?
i bought from amazon.de shenzenaudio. I plan to send it back.
Is this the newest driver?I have m500 v1 version and XMOS 5.12 driver.
The 32-bit option that previously existed has disappeared from Windows.
Please help me.
Did you try to update firmware and back to stock version?The 32-bit option that previously existed has disappeared from Windows.
I suspect that's what happened.
What is the firmware version in XMOS control panel? E.g. mine is 2.06 (see the attached image).
Isn't it a pure hardware issue? If so, I assume a firmware upgrade would not make any difference?a firmware Upgrade because of the 3rd harmonic issue
they replaced my v1 with a v2 and then upgraded it. it's a software fix but only works for the v2.Isn't it a pure hardware issue? If so, I assume a firmware upgrade would not make any difference?
V2 allows firmware upgrades, correct.they replaced my v1 with a v2 and then upgraded it. it's a software fix but only works for the v2.
Please read the 3rd harmonic thread, in case you are interested. Maybe there is some kind of misunderstanding, here.V2 allows firmware upgrades, correct.
Nothing to do with the third harmonic issue...
just dont mention it. tell them you want the 3rd harmonics issue fixed and you will get a v2. it shouldnt matter if previous firmware uogrades failed or not. just dont mention it because it is irrelevant. once they have the device in their posession, they can make a plan how to get the fixed firmware onto the device or send you a replacement unit.@jani80k It has been over a year since I purchased this product, so I am not sure if it is eligible for a replacement. However, since it is not my fault, it is a defect in the device itself, so I think it will be possible to exchange it.
When my new dac arrives, I will apply to have it repaired. Thank you.
