@A Surfer If I am not mistaken this phenomenon would just lead to a dropout in sound for one or two seconds, as was reported by multiple SU-8 users. In other words - you're watching a movie on Netflix using your awesome speakers and as the bandwidth changes you get several pauses in sound throughout the movie (unacceptable in my opinion).Oh no, the issue is is that the Altera FPGA re-clocks the incoming signal into a super clean dejittered output, but the locking is often troublesome on jittery sources like (smart) TVs, chromecast etc. Since you can't play around with the lock/DPLL strength, if it doesn't work well there's nothing you can do, as opposed to SU-9 where it is configurable. There was never an audible issue, rest assured.
Thanks for the clarification. Much appreciated.Oh no, the issue is is that the Altera FPGA re-clocks the incoming signal into a super clean dejittered output, but the locking is often troublesome on jittery sources like (smart) TVs, chromecast etc. Since you can't play around with the lock/DPLL strength, if it doesn't work well there's nothing you can do, as opposed to SU-9 where it is configurable. There was never an audible issue, rest assured.
Does M200 beat D50S?I had the Topping D50s but decided to sell that with the P50 power supply because I wasn't happy with the A50 headphone amp and wanted a matching stack. I've only spent about £20/30 for the whole replacement so it was worth it.
They sound awesome. Or I should say the music sounds awesome and I can't hear either the amp or the DAC. More volume just gives louder music and no colouration. I absolutely love them. I got a big improvement with the XLRs over RCAs and I'm waiting for the 4 pin XLR cable to finish it off. I'll be drawing a line under my headphone purchases now but will try to put a bit of cash aside each month for a Christmas headphone present to myself : )
I personally think they look awful but it's been good for me to put that out of my mind and concentrate on the sound only. The appearance is growing on me but I'll never get over the slant and I can't understand why they don't match at all! Still awesome sounding gear though.
I tried several times: turn off the DAC with the remote and replay the music, everything works fine, no problem.
Does not correspond to the problem I have occasionally, i.e. when I lose the connection, for example I go outside to do my grocery shopping, I come back and the connection is made but no sound, I do not that unlink it and reconnect and everything works.
It is sorry for you. I imagine it may be a defective lot. With mine, it works every day without any problems. At first I had some problems with an LG G5. Now it's a Samsung S10. In your case, the problem does not appear to be cellular. Ldac is easily compatible from Android 8 I believe. Yes the M200 is really musical.[/QUOTE
Firmware correctable?
Just got my M200 and I have a bit of a weird question. Should the knob control volume? Both the up and down on the remote and the knob don't let me adjust the volume. Is there something I have to do in the menu or is my unit faulty?
Yes, The comparison between M200 and M400 is not only the ak4497 to Ak4499 on the chip, but also the design and functional upgrade of the entire decoder. The power supply is also better. https://hifi-express.com/products/smsl-m400-mqa-ak4499-dac-pre-order-discountI have the M200, is it worth upgrading to M400?
Can get it from here and Shipment from multiple warehouses around the world.
May someone can reply you.Thanks for your reply, but I'd like someone NOT the manufacture to tell me to spend my money for their profit
M400 or Loxjie d50?
