Hi all,
as you can see I am on the hunt for the end game dac/amp to use on my Audeze lcd x (2021)
i will be using these headphones for 4k movies, no mixing or mastering music.
I pretty much like neutral, warm sound with very fast and punchy bass with great dynamic range and headroom. I currently use the dt 1990 pro and fiio k7 with harman eq and i really like the sound however i want a new set up for another computer which ideally needs to be a step up of what I currently own.
above are some amps/dacs that i can buy. There is also a local guy that has the SMSL M400+SMSL SP400 combo which he is selling for a very good price, but budget isnt really an issue. I am taking everything into consideration especially the ones I mentioned above.
which one would you go for and why? how do you rank these from best to worst including sound quality?
i will not be using inbuilt eq and bluetooth.
