Hi there,
Does someone know how much mW are needed to drive well the HD650 ?
For me to know if a dongle is enough with something like 14 mW at 300 Ohms.
Thank you !
The test below was done using the HD650:
The part of the recording shown below was playing
very softly, think soft level when listening in the evening. The level where you can easily listen for a whole evening while having the urge to turn up the volume a bit.
This is slightly below the level I usually listen at. My ‘normal’ listening level is around 75dB average.
This resulted in the following (rounded off) numbers:
RMS levels = 23mV = 0.0017mW =
70dB (average)
Peak levels = 245mVPP = 87mVRMS = 0.023mW = 82dB
calculated DR = 11.5dB for that 10 sec of the song.
The plot below shows part of the recording was playing at a
very comfortable level that is a fair bit louder than the soft level. You can listen a whole evening to this level. This is slightly above the level I usually listen at.
On lower DR recordings you like to turn it down a slight nudge, higher DR recordings you may feel the urge to turn it up a tad.
RMS levels = 75mV = 0.018mW =
80dB (average)
Peak levels = 830mVPP = 293mVRMS = 0.26mW = 92dB
calculated DR = 11.8dB for that 10 sec of the song.
The part of the recording below was playing at a
comfortably loud level which is easy to listen to for 1 or 2 songs before getting the urge to turn it down to more comfortable levels.
When I really like a song I might turn up the volume to this level but turn it down again after 1 or 2 songs.
RMS levels = 236mV = 0.174 mW =
90dB (average)
Peak levels = 2.63VPP = 930mVRMS = 2.7mW = 102dB
calculated DR = 11.9dB for that 10 sec part of the song
This part of the recording below was playing
uncomfortably loud. It is the type of level where you turn up the volume because you either like the song very much or want to listen ‘deep’ in the recording to evaluate.
Not a level you would gladly endure for the whole song.
RMS levels = 510mV = 0.81mW =
97dB (average)
Peak levels = 9.16VPP = 3.24VRMS = 33mW = 113dB
calculated DR = 16dB for that 10 sec part of the song
(this was the intro of the song by the way)
Here the music is playing at quite
uncomfortably loud levels. One may use these levels for listening ‘in the recording’ for analytic purposes to check for distortions or find noise levels in the recording.
These levels are certainly NOT used for pleasantly enjoying music and one, for sure, cannot maintain to listen to these levels for the whole song.
It should be noted though that this is a DR13 recording and this particular part was ‘just’ 12dB DR.
When listening to DR20 recordings the average levels will be quite loud but the peak levels will reach about the same 117dB peak levels.
The amplifier started clipping the highest peaks already which added a sharp ‘edge’ at certain peaks.
I would not call those peaks anywhere near ‘pain levels’ though but ‘very loud’ none the less.
RMS levels = 1.35V = 5.6mW =
105dB (average)
Peak levels = 15VPP = 5.3VRMS = 88mW =
117dB peak
calculated DR = 11.9dB for that 10 sec part of the song.
I certainly do not recommend listening to these levels for longer than 1 minute or so.
This data shows that to drive the HD650’s to uncomfortable loud levels while still not nearing any clipping levels and having a few dB extra headroom you will need an amplifier that can supply at least 10VRMS which means the amplifier must be able to supply 300mW into 300Ω headphones.
To drive the HD650 to
comfortably loud levels you only need around
1.7VRMS = 10mW into 300Ω though.
A source that is specified to reach 100mW
in 32Ω thus will be able to do that job.
In other words... how much voltage (power) you need depends on how loud one wants to listen to occasionally without ever hitting distortion of the amp.
The thing about amplifiers is that peak voltages can consist of many different frequencies that by themselves are not very loud but all add in the signal.
