I think most of their fanbase simply don't care, viewing tonality as an artistic interpretation of music, where the manufacturer is the interpreter and each headphone is different.I think customers are not very well aware of how these headphones measure.
I guess that is really what many audiophools think, sometimes called "tastefull coloration", often accompanied by tube sound and R2R DACs (distortion). GoldenSound is a promiment proponent of this 'ideas', although he should and in fact does know better. I think everybody who is clear in his mind realizes that this completely contradicts the concept of high fidelity, but arguments, education or a discussion are mostly in vain on adherents to these views.I think most of their fanbase simply don't care, viewing tonality as an artistic interpretation of music, where the manufacturer is the interpreter and each headphone is different.
As someone who ~nearly~ bought a ZMF headphone, I can say that the aesthetics play a huge part in the overall quality judgement.I think customers are not very well aware of how these headphones measure. So little independent reporting. And even those (reviewers) that measure, are motivated to say everything expensive is good. So purchases are made and companies think they are doing the right thing.
It does for me as well. I really like to have such products do well.....As someone who ~nearly~ bought a ZMF headphone, I can say that the aesthetics play a huge part in the overall quality judgement.
This is a review, listening test, detailed measurements and equalization of ZMF Atrium Closed headphone. It is on kind loan from a member and costs US $2,500.
The headphone feels and looks high-end with the unique wood cups and leather work. It was comfortable to wear but is extremely difficult to adjust the headband height. It takes a lot of force to adjust it at which point, it jumps a number of detents.
I was surprised that despite the large cups, it was rather difficult to get consistent measurements. Difficulty of adjusting the headband didn't help in this regard. Looking online, I found differing measurements. Mine below correlates best with the company measurements published in a video.
FYI I sent the frequency response a couple of days ago to the designer for input but did not hear back.
ZMF Atrium Closed Headphone Measurements
As usual, we start with our frequency response measurement and comparison to target using GRAS 45CA fixture:
I had to spend nearly half hour to get the right channel to be close to the left channel and at maximum bass output. I like that there is ample bass but very disappointed in that huge trough centered around 1.8 kHz. This number will keep coming up as you will see below. Such a suck-out will take the life out of vocals and spatial qualities from my experience.
Relative target shows that exact compensating EQ by eye will be challenging:
But we will try in the next section.
Distortion measurement shows sharply increasing levels at you guessed it, 1.8 kHz:
I marked it as a resonance but looking at it now, it is wide so my have other causes. Regardless, such high distortion where our hearing starts to get very sensitive is not a welcome addition by the headphone. Distortion measurements may not be predictive of preference but they are a wonderful tool in the way they show defects in design.
Group delay is more messy than I am used to seeing in bass frequency and also shows a dip where our 1.8 kHz disturbance lives:
Headphone is high so you want a headphone amp with high voltage drive:
And yes, we see a disturbance in the impedance graph at 1.8 kHz which means it is a major acoustic event.
Sensitively is below average so you want a good headphone amp to drive it if you want to play loud:
ZMF Atrium Closed Listening Tests and Equalization
Immediate impression is that of bass which is not so bad. But eq that trough and you realize what you are missing in upper midrange/lower treble:
Band 3 is doing all the heavy lifting. The rest are complimentary but may depend on your taste. The triple filters in bass tightened its response which I prefer. Some may want the warmth without.
Tailoring the 1.8 kHz filter to the frequency response with the other two was high and miss. But I tried.
It is very obvious that the company has its own ideas of what tonality people like. And that is something that has little to do with the research over a decade that says otherwise. Shame is, company has extensive measurement tools. What it is used for, I don't know.
Further, it seems sometimes that I am the only one caring about proper engineering through my distortion tests. The same measurement that produces the frequency response also outputs THD (both absolute and relative). So the designer is a click away from discovering anomalies that need to be investigated and remedied.
And it is not just objective measurements: listening tests clearly show massive response errors if you perform AB with and without correction. To be sure, as is response is not annoying. It just muffles the heck out of good part of the music spectrum.
I know I am being a bit harsh with my rating here but at some point, we need to stomp our feet and get companies to either follow the research or prove the research is wrong. Creating random response in such an expensive headphone is just wrong.
Needless to say, I can't recommend the ZMF Atrium Closed. As a woodworker, it aches my heart to have written that but I have no choice.
ZMF Atrium Closed APO EQ Score Flat@HF 96000Hz
July032025-151120
Preamp: -9.70 dB
Filter 1: ON PK Fc 196.5 Hz Gain 6.91 dB Q 1.90
Filter 2: ON PK Fc 210.5 Hz Gain -5.78 dB Q 0.73
Filter 3: ON PK Fc 645.3 Hz Gain 2.24 dB Q 2.88
Filter 4: ON PK Fc 1856.2 Hz Gain 9.74 dB Q 1.65
Filter 5: ON PK Fc 3210.6 Hz Gain 3.16 dB Q 4.97
Filter 6: ON PK Fc 5223.7 Hz Gain -5.18 dB Q 5.00
Wow, I don't remember any headphone that is even after EQ so distant from the target, so it is actually beyond EQ salvation, oh boy...Here are some thoughts about the EQ.
Please report your findings, positive or negative!
Notes about the EQ design:
average L/R match.
- The average L/R is used to calculate the score.
- The resolution is 12 points per octave interpolated from the raw data (provided by @amirm)
- A Genetic Algorithm is used to optimize the EQ.
- The EQ Score is designed to MAXIMIZE the Score WHILE fitting the Harman target curve (and other constraints) with a fixed complexity.
This will avoid weird results if one only optimizes for the Score, start your journey here or there.
There is a presentation by S. Olive here.
It will probably flatten the Error regression doing so, the tonal balance should be therefore more neutral.- The EQs are starting point and may require tuning (certainly at LF and maybe at HF).
- The range around and above 10kHz is usually not EQed unless smooth enough to do so.
- I am using PEQ (PK) as from my experience the definition is more consistent across different DSP/platform implementations than shelves.
- With some HP/amp combo, the boosts and preamp gain (loss of Dynamic range) need to be carefully considered to avoid issues with, amongst other things, too low a Max SPL or damaging your device. You have beed warned.
- Not all units of the same product are made equal. The EQ is based on the measurements of a single unit. YMMV with regard to the very unit you are trying this EQ on.
- I sometimes use variations of the Harman curve for some reasons. See rational here and here
- NOTE: the score then calculated is not comparable to the scores derived from the default Harman target curve if not otherwise noted.
I have generated one EQ, the APO config file is attached.
For once same number of BQ for both my EQ and Amirm's.
Score no EQ: 38.4
Score Amirm: 54.0
Score with EQ: 65.4
Code:ZMF Atrium Closed APO EQ Score Flat@HF 96000Hz July032025-151120 Preamp: -9.70 dB Filter 1: ON PK Fc 196.5 Hz Gain 6.91 dB Q 1.90 Filter 2: ON PK Fc 210.5 Hz Gain -5.78 dB Q 0.73 Filter 3: ON PK Fc 645.3 Hz Gain 2.24 dB Q 2.88 Filter 4: ON PK Fc 1856.2 Hz Gain 9.74 dB Q 1.65 Filter 5: ON PK Fc 3210.6 Hz Gain 3.16 dB Q 4.97 Filter 6: ON PK Fc 5223.7 Hz Gain -5.18 dB Q 5.00
I like the caldera open better than any planar I've heard for my metal needs aside from Grado headphones, which probably goes down as number 2 favorite metal headphones of all time.
Maybe one day make a test if you would pass as a skilled or trained listener. My guess, with all the due respect, is no.I loved this headphone for my hip/hop music taste. This was without looking at measurements.
I think measurements are important to see what works for you and maybe as a guideline. But I honestly would if possibly listen first before passing final judgment.
I liked this better than the DCA stealth by a large margin.
I loved the DCA norie better than the Atticus or the eikon.
There are people who like it and people who don't. Nobody is right here imo. ![]()
Does it matter if I'm a "skilled listener"? If I put it on my head and it sounds awesome? What more skill do I need?Maybe one day make a test if you would pass as a skilled or trained listener. My guess, with all the due respect, is no.
Nope. I actually started with the sr-80 and was blown away. I have sense moved on. But might return with the rs1x for my Americana needs.There’s no scenario where Grado are good, and to listen to shouty, peaky heavy metal on such headphones must be tortuous unless you suffer from partial hearing loss
At least listen to other, better headphones. I described my impressions on the previous page, for instance. And I don't think they sound "awesome" or just good.If I put it on my head and it sounds awesome?
I just read your impressions. I think it's totally valid. You did not like the same thing I liked and there is nothing wrong with that . I've tried many headphones over the years. For instance the susvara really is a headphone I was not impressed by.At least listen to other, better headphones. I described my impressions on the previous page, for instance. And I don't think they sound "awesome" or just good.
Thank you and I believe this is a balanced response. I found the thread interesting and decided to just state my experience with the headphone. Lol. Not sure why these people are so upset and telling me I'm wrong. I did not make any outlandish claims or go on with flowery language about buttery midrange for example.Let's remember that tastes differ and not everyone prefers the Harman target.
Let's also keep in mind that the way certain genres are recorded certain colored headphones may even sound 'more pleasant'.
When it comes to measured performance on specific test fixtures and adhering to a specific target there is little room for discussion.
When it comes to taste/preference and subjective found differences and using EQ or not (and the correct EQ) there is certainly room for divergence in opinions.
And the measurements is what respondents base their opinion on. Most people never get to actually hear/feel/handle ZMF headphones.When it comes to measured performance on specific test fixtures and adhering to a specific target there is little room for discussion (science)
