ZMF Atrium Closed Headphone Review
Rate this headphone:
    Votes: 189 83.6%
    Votes: 19 8.4%
    Votes: 6 2.7%
    Votes: 12 5.3%
This is a review, listening test, detailed measurements and equalization of ZMF Atrium Closed headphone. It is on kind loan from a member and costs US $2,500.
The headphone feels and looks high-end with the unique wood cups and leather work. It was comfortable to wear but is extremely difficult to adjust the headband height. It takes a lot of force to adjust it at which point, it jumps a number of detents.
I was surprised that despite the large cups, it was rather difficult to get consistent measurements. Difficulty of adjusting the headband didn't help in this regard. Looking online, I found differing measurements. Mine below correlates best with the company measurements published in a video.
FYI I sent the frequency response a couple of days ago to the designer for input but did not hear back.
ZMF Atrium Closed Headphone Measurements
As usual, we start with our frequency response measurement and comparison to target using GRAS 45CA fixture:
I had to spend nearly half hour to get the right channel to be close to the left channel and at maximum bass output. I like that there is ample bass but very disappointed in that huge trough centered around 1.8 kHz. This number will keep coming up as you will see below. Such a suck-out will take the life out of vocals and spatial qualities from my experience.
Relative target shows that exact compensating EQ by eye will be challenging:
ZMF Atrium Closed Headphone frequency relative target response measurement.png
But we will try in the next section.
Distortion measurement shows sharply increasing levels at you guessed it, 1.8 kHz:
I marked it as a resonance but looking at it now, it is wide so my have other causes. Regardless, such high distortion where our hearing starts to get very sensitive is not a welcome addition by the headphone. Distortion measurements may not be predictive of preference but they are a wonderful tool in the way they show defects in design.
Group delay is more messy than I am used to seeing in bass frequency and also shows a dip where our 1.8 kHz disturbance lives:
Headphone is high so you want a headphone amp with high voltage drive:
And yes, we see a disturbance in the impedance graph at 1.8 kHz which means it is a major acoustic event.
Sensitively is below average so you want a good headphone amp to drive it if you want to play loud:
ZMF Atrium Closed Listening Tests and Equalization
Immediate impression is that of bass which is not so bad. But eq that trough and you realize what you are missing in upper midrange/lower treble:
Band 3 is doing all the heavy lifting. The rest are complimentary but may depend on your taste. The triple filters in bass tightened its response which I prefer. Some may want the warmth without.
Tailoring the 1.8 kHz filter to the frequency response with the other two was high and miss. But I tried. :)
It is very obvious that the company has its own ideas of what tonality people like. And that is something that has little to do with the research over a decade that says otherwise. Shame is, company has extensive measurement tools. What it is used for, I don't know.
Further, it seems sometimes that I am the only one caring about proper engineering through my distortion tests. The same measurement that produces the frequency response also outputs THD (both absolute and relative). So the designer is a click away from discovering anomalies that need to be investigated and remedied.
And it is not just objective measurements: listening tests clearly show massive response errors if you perform AB with and without correction. To be sure, as is response is not annoying. It just muffles the heck out of good part of the music spectrum.
I know I am being a bit harsh with my rating here but at some point, we need to stomp our feet and get companies to either follow the research or prove the research is wrong. Creating random response in such an expensive headphone is just wrong.
Needless to say, I can't recommend the ZMF Atrium Closed. As a woodworker, it aches my heart to have written that but I have no choice.
Reserved for @RickS to kindly post the specs.
SPECIFICATIONS
  • Impedance: 300 Ohms
  • Driver: Biocellulose N52 Atrium Tuned Driver
  • Weight: 490g ± 30g (aluminum chassis, black grille/rods)
  • MAG Chassis reduces weight by 34g
  • Sensitivity: ~96dB/mW
I happen to have listened to this headphone a few weeks ago, and I didn't like it. I remember it felt off at the treble region just like shown in the measurements. It was also quite heavy, I don't think I would have been able to use it for as long as I do other cans. Looks nice though.
I, for one, have never really like the Britiish Gentleman's Club wooden cup style earphone. To me it add weight, maintenance needs, and resonances. And it kinda shows in this design, doesn't it? Seems like it was built to create an aura of something plush and handcrafted, rather than being something designed to optimize performance.
In any case, thanks for the very nice review Amir.
Amusing the way the height adjusters stick up like antennae, My Favorite Martian style.
ZMF fanboys will find baroque justifications for all the critizisms stated. Reasonable people will stay away from this headphone, which may look nice, but offers no real benefit. You can get 15 Fiio FT1's for the price. True, those were most likely not produced by hand in a small manufacture, but offer much better sound and no horrible distortion peaks or channel imbalances.
It's too bad, the headphones look beautiful and I had a good impression of Zach when I met him years ago. The POV here is clearly that a different tuning is a better way to go, which of course doesn't earn high ratings here.
Interestingly there was a discussion of the parts Express Opal speaker and it's very non flat, but very likely intentionally so tuning. On some level it's hard to understand why a competent designer would do the "wrong' tuning. But considering that many other skilled engineers are going for the same tuning, and at least some consumers prefer these random tunings... It may make good business sense.
"Love it or hate it" tuning will find at least a few that love it. 4th best Harman tuned headphone at $X price point can be a harder position to sell from.
Just some thoughts...
Seems like an overly dark headphone.
Below an SBAF measurement from Vtory (who does great reviews by the way) and uses SBAF-compensated EARS mini DSP measurements.
So... best to use comparative measurements with known headphones.
Below the Atrium Closed versus DCA Stealth
This confirms Amir's measurements (dark tonal balance with a substantial dip around 2kHz and a bit 'wonky' treble response with 10dB variations.
Below (Head-fi) Jude's comparison (BK5128) between Atrium Closed (continuous line) and the Verite closed (dotted line)
Here too... very dark signature, substantial dip at 2kHz and 'wonky' treble response (10dB variations)
As usual... the woodwork is excellent so is the build quality/looks.
Below some background info on this headphone by the manufacturer.
Basically, all their products are overpriced trash, with prices dictated by their greed and marketing budgets that go into buying reviews from clueless and unashamed youtubers.
Very disappointing. I was seriously considering the Verite Close but this review makes me question the brand reputation.
Thanks Amir for the honest review.
I don't think trash is a fair descriptor at all. Grossly overpriced as a sound reproduction device yes, but trash, no.
I have been on Head fi for many years and it always shocked me that people were willing to pay such a premium for nothing related to sound, just the look of the wooden cups.
I remember commenting in that community about the availability of fine works of actual wooden pieces of art, crafted as objects of art that could be purchased for less than these ZMF headphones. But it falls on deaf ears. There are people who collect ZMF headphones like people collect art objects. It defies all logic.
Essentially people pay Zach, a nice person by all accounts, a massive premium to indulge in his true passion, collecting and working with wood.
There are many ZMF fans who actually believe that the different wood choices effect the sound audibly which seems like people who believe in custom cables to me. In fact over at Head fi you will see the saddest of all misinformed people who spend massive money on these wooden cupped headphones and then go equally deep into buying the best aftermarket cable to synergize with the type of wood. Truly painful to read.
Reminds me of that old, and somewhat unkind, saying a fool and their money is soon parted.
On the contrary, I think what's really a bit harsh is for ZMF to launch a headphone with such glaring defects, and with such a price tag, in this age and time.
The more expensive the headphones, the riskier for the panther...
