I’m sorry this thread has not been providing the entertainment value you so desire. After all, my primary desire when starting this thread was to cultivate the entertainment of readers to the maximal extent, rather than to gather/exchange objective data, knowledge, and advise relevant to my particular situation and purchasing decision.I think the discussion is getting boring so I would like to suggest something different:
PSI A23-M.
Joking aside, please provide a link to measurements of your suggestion, or its not worth posting here or anywhere on this science/measurements-focused forum.
PSI A23-M.
Though correct me if I’m wrong, but the KH420 seems to have a flatter on-axis response AND smoother horizontal off-axis contours than the Genelec 8361A. That could just as well bug me for speakers so expensive, unless I’m reading these charts wrong.
The Genelec 8351B looks clearly better than either at least for on-axis flatness, but it also won’t compete with the bass power from the KH420 or Genelec 8361A.
Just saying that there are always tradeoffs.
https://www.audiosciencereview.com/forum/index.php?threads/danley-studio-2.13208/
Danley Studio Two just came out. A powered speaker with passive XO, yes, but Danley is one of the leading engineering-focused firms out there with its Synergy design. Alternatively, a more traditional Danley horn (preferably with subs) - SH-50 is quite popular with home audio. The Danley thread also mentioned Ocean Way HR-4/5 with matching subs (HR-5 is on the way to be measured by Amir). Unusual wide baffle design with midwoofer and tweeter horns, that would promise high SPL and directivity control if done well.
I would personally hold off on Neumanns. With the KH80DSP out I have no doubt they are going to expand the DSP platform to the larger speakers in the line, so the 420 are probably quite close to EOL. The KH80 is noticably more linear within its passband than the (already-excellent) larger speakers in the line.
The 8361s would definitely make the most sense - new release from an established brand's state-of-the-art lineup that has just reached maturity (8351A's problems seem to be almost eliminated). Then come the usual suspects of Kii, DD and now, GGNTKT (been discussed on ASR with detailed manufacturer measurements). Danley has similar coaxial virtues, thought FR is likely to be slightly more ragged, but with vastly higher SPL ability. Pick your tradeoffs.
Notably smaller and less extended than the options being discussed here. The analog phase linearisation is another one of those romanticised features that add excess cost, making PSI speakers far from the performance/price leaders. I don't place it too far off other speakers that are romanticised based on a cult of personality more than performance. Think Thiel, Vandersteen, ATC, PMC and so on.
You're right. I do think that the 8351B is the best of all the ones being discussed in this thread. You're totally correct it doesn't have quite as much bass power, but I'm really not sure that will matter in a relatively small office with plenty of room reinforcement, unless you have a really big one of course
It's also my personal choice, and for more bass I am adding subs(not to suggest that to you, as you've been clear about your desire not to have them!). I do think that it's pretty difficult to get quality bass out of a pair of speakers, no matter their anechoic measurements, especially ones that aren't gigantic floorstanders.
And certainly, I'm not suggesting that any Neumanns are a BAD speaker -- I have KH80s myself! They're solid. We're arguing speculating and arguing over molehills here at this point.
You are overselling DSP design, and if you think pure analog is overrated including ATC, then you need to hear some ATC50 or higher in a good room, they are NOT overrated. Also the KH310 bought up many times here, the A version is pure analog too and measures extremely well, especially for the price.
You seem to be a bit like me in what you want to avoid.I understand this route and have tried it, and still find e.g. the Neumann KH310 is better tuned and somehow higher fidelity sound across mid bass frequencies than anything I can achieve with this approach of manually tuning subwoofer crossovers that generally sweep through that critical bass to mid bass region.
I want a simple stereo set of two speakers that I can buy that sounds amazing without a ton of tedious hand-tuning, and takes less space and fewer pieces than two subs, two speakers, and several MiniDSP unite with a massive tangle of power cables and signal cables sprawled everywhere.
In other words, I don’t want to engineer an integrated speaker system, I want to buy one. The Neumann KH310 actually achieves this for me fantastically well, aside from deep sub bass extension. For my office setup, it’s nearly perfect. But I‘m curious to explore potential upgrades, especially now during the time when one of my KH310s has to be sent back to fix a rattle it seems to have developed.
I wouldn't count on this. I rather expect that speakers are updated in order of appearance, so 120, 310, and at last 420. Or we might see a 510 (successor of K&H O500C).I would personally hold off on Neumanns. With the KH80DSP out I have no doubt they are going to expand the DSP platform to the larger speakers in the line, so the 420 are probably quite close to EOL.
https://www.audiosciencereview.com/...ased-speaker-designs.6441/page-51#post-398172
Ah, more unsubstantiated ATC magic. Tell me where the magic is considering Neumann's 3" mid dome has the same distortion level at 10dB higher SPL as ATCs - and it has a smaller footprint than the ATC dome. The British monitor cult of personality is one of the strongest in the industry. They all have a superficial commitment to engineering, yet release merely incremental improvements on rustic designs under an outdated engineering paradigm. See more measurements here.
Pure analog is okay. In principle I like avoiding excess AD/DA too. Less points of failure. In fact, I always recommend the Genelec 8030/8050 over the 8330/8350 (8040 has not been revised yet). But tedious analog phase linearisation (as in the PSI, but not the Neumann) that inflates the price for the form factor (nearly 10k for an 8" 3-way when we have significantly larger and well engineered designs!) not so much, when the evidence for phase audibility in speakers is insignificant.
Not going to bother argue with you on ATC, but you need to at least look at spec before giving other people advise. Genelec, unlike some other DPS speaker makers, let you avoid AD/DA process by taking AES digital input... Also there is a 8340, and like 8350, it also take AES digital input...
OTOH they may update them simply in the model order in which DSP offers the biggest performace increment (which would probably be this order anyway)I wouldn't count on this. I rather expect that speakers are updated in order of appearance, so 120, 310, and at last 420. Or we might see a 510 (successor of K&H O500C).
Yes, except AES out is rare in home audio. OP doesn't have AES out from the setup in his signature, so unless he is overhauling his source too, it isn't particularly relevant to this thread.
Just admit you are wrong and move on, you didn't even know 8340s exist and like to advise people on which Genelec to pick... USB or S/PDIF to AES device are readily available and not like they cost a fortune.
You could get a Genelec sub (7360) if you have an issue (though it probably pushes you past your budget a little bit). It would probably free up some SPL in the 8351B and also extend lower. At least, this is what I am telling myself. I would really like to hear them though to know for sure.
At that rate the 420 would have 20 year lifecycle. Not sure whether to be impressed that it is so advanced that it's still in the SOTA ballpark, or dismayed that no one has managed to catch up and undercut it despite the tech and capabilities being out there for a long time.
I do. Obviously the 8040/8340 exist. I was saying I generally prefer recommending the analog Genelecs. The reason is not just AD/DA, but paying a premium for a closed ecosystem (GLM) with limited capability compared to more advanced systems (eg. Acourate) that can be used for any speaker.
Of the analog Genelecs, the 8030 and 8050 have better directivity performance than the 8040. The 8030 and 8050 have both been revised acoustically. 8040 only had revisions in the power-saving circuit from release in 2004, no acoustic improvements. Did you know that? It's the odd one in the line-up. Hence me deliberately dropping both the 8040 and 8340 from recommendations for both reasons.
Again, the more you keep going we know more about your ignorance and how you like to try to be a know it all. People have asked the difference between 8050B and 8050A, you know what answer Genelec gave? The answer is also the only difference is the power saving feature, they sound the same. I am even going to find you the link:
https://www.community.genelec.com/forum/-/message_boards/message/906215#/
