- Joined
- Oct 1, 2018
- Messages
- 826
- Likes
- 1,226
I can't find measurements for ATC SCM50 100 OR 150 anywhere.
I guess that the dip at 3.5kHz is bad?
Those don't look like the speakers I was talking about. Those look like floor standers. Not sure if it matters. Also I don't know if it matters in regards to if the active vs passive would measure different but those are the passives in that particular review I think. edit. nevermind, I guess the right speaker in that one is the active version. I can't read that language so I had to take a closer look. It looks like there's a 4 or 6dB dip in the crossover of the midrange driver at 3.5kHZ which maybe is what ilkness was talking about. I've never really understood how graphs work even though Amir includes them in his speaker reviews. I guess that the dip at 3.5kHz is bad? I know my speakers have a small dip at the crossover point at 700hz but apparently that is less of an issue because it's at a lower frequency.
Not sure what to think, I will have to do a lot more research and of course hear the speakers myself. One thing that I wonder about atc and why someone might not be enamoured with their sound is the fact that apparently atc needs placement in treated rooms to sound their best and also I’ve heard reports at least regarding the scm150 that they sound rather unengaging at low volumes. Could anyone offer a suggestion why that may be?
I had the active 50s here, after everything I had read ( mid range dome blah blah) they were disappointing compared to contemporary designs.
Not unlike the BBC designs and Quad for that matter which must have been exceptional fifty years ago.
I have to correct some comments I made about the scm50 measurements from what tuga posted. It looks like it’s +/-2dB from 60-20kHz, not 4-6dB at least according to stereoplay themselves.
And thanks for your subjective opinion Keith but I have to take your comments with a grain of salt because you’re a dealer. I was about to say you don’t represent atc so of course you wouldn’t feel obligated to praise a brand you don’t carry but you actually do carry atc since I visited your website to check.
You have the scm50 you mentioned listed on your site along with some words I noticed “'I have the simplest of tastes I am always satisfied with the best. ATC have and continue to make the very best loudspeakers available, the complete range of ATC loudspeakers and electronics are available from Purité Audio.”
Outdated text in your site from before you stated carrying Kii and Grimm speakers? We know you prefer DSP based systems. So I guess it would make sense you prefer those brands. Interesting how people can label a brand as “the best” but a few short years later the latest and greatest thing overtakes it completely...
CtC = centre to centre spacing.
Because of that old-fashioned motor design, it has a huge, bulky flange/driver frame that increases CtC spacing needed. For a given crossover frequency, larger CtC = worse vertical performance due to lobing. Now this driver is well-behaved to a pretty high frequency. But all that performance is wasted because you have to cross it lower than that (thus defeating the point of the expensive driver), or start compromising vertical performance and make it very finicky to listening height.
Hence the comparison to Neumann's mid dome, which has almost JBL M2 level of measured headroom and distortion in a much more compact frame and vastly better directivity control than that ATC paperweight. I frankly don't rank them much higher than PMC or Harbeth.
I guess you could say it is bad since it looks like it's caused by the breakup resonance of the mid dome.
They are the very antithesis of a design like your JBLs - namely controlling dispersion and modern driver designs (eg. JBL differential drive woofers and the D2 compression driver). This is seen in the pedestrian directivity performance and clunky box.
I doubt the dome mid is breaking up that low in frequency. Much more likely to be destructive interference around the XO point IMHO, especially given we see evidence of lobing around the same frequency in the vertical off-axis measurements.
Why do you assume that what he likes about his JBLs (or doesn't, since he is looking at replacing them) is the result of controlling dispersion and modern driver designs?
Have never heard the Neumann’s, but they are pretty pricey here in the states. For close to $10K a pair for the KH420, I have really high expectations. I know stuff in Singapore is generally even more, but if am just spending freely, the JBL M2 seems like a lot more speaker?
It's also worth mentioning here that Toole research in this area is clearly limited to the acoustic environments he experimented with. If you have for instance a late lateral diffuse tail in the room, things can change quite dramatically.
You jumped into this conversation:
I explained what they issues are in interpreting them. And their usefulness. And the signal processing behind it. As asked by Ray.
You challenged my statement so I explained it again in more detail.
If you are asking simply if you can use ETC for timing detection, which is not what was asked or being discussed, you can. There are dead simple substitutes that don't require ETC such as just looking at the room, using a mirror, tape measure, etc.
But if you want to use ETC, is fine. Just don't go to the next sentence as you do that people should assign value to those reflections and go and try to eliminate them all. If you do, then you run foul of what I explained.
to be frank: you seem to have this habit of associating the use of a tool (the ETC/time-domain analysis) as an automatic insinuation of implying that "every spike of energy must be attenuated". it's quite frankly laughable. a user first sets forth time-domain requirements - and the ETC is used to understand existing environment and thus what modifications need to be made in order to meet the end-state response. a tool does not "tell you what to do". a user identifies where they are currently at, and their end-state, and the tool helps provide validation after the changes have been made.
Membership here is not familiar with you, your personality and knowledge level. I wanted to make sure they were up to speed that you just repeat stuff you learned from some old text (Davis) which you misread and some random dude online who claimed to know the topic. And that you will grab on someone's pant leg and won't let go with this ETC talk. If none of this is you, then update us so we know.
