Right right....And you know more about this than Paul indeed! ..... And you will integrate it better than a speaker designer could?? when he's starting from the ground up on a speaker's design. Man, such confidence oozing from the ignoramiiiii these days...lol
I'm terribly sorry if it shatters your world to hear that not
everybody in the 2-channel Hi-Fi industry knows
everything about products they do not sell and their customers by and large do not use.
How many dofs do you have for your sub dude? Let's see,,, a volume control, crossover and lousy lil 0/180 phase flip switch on most subs out there. It's a bit more with a Rythmik, i suppose.
The "dofs" offered by DSP integration can be substantially to infinitely greater than the above. None of Paul's products offer this capability. Here he explains why:
The primary reason given--that amplifiers all "sound different" and sending the high level signal from your
unique amplifier to the sub ensures that its signature sound is also given to the sub, therefore it will blend better with the speaker because it will take on the same character of that unique amplifier...is, I'm sorry, but simply ludicrous. Even if one accepts that we'd hear a difference between amplifiers on the main speakers, our ears are simply not that discerning below 50 Hz. At those frequencies you want lots of power--it can be Class D and it can be cheap--no, you won't hear a difference. Any concern beyond that is a waste of money.
Setting that aside, he always recommends running the main speakers full range and only adding in the sub where they roll off. As I stated in the "High-pass for mains" thread, this is a legitimate way of doing it and it can offer good results for many people depending upon their setup. However that won't be most people, especially those using bookshelves (as the questioner in this and other videos have) that will distort a large amount (relative to a good sub) at those frequencies when played at a decent volume. Most of these people will find better results by using an actual crossover that high-passes the mains.
One of the first things I always recommend to those who want to get the best integration--and avoid being an "
ignoramiiiii"--is to get a microphone and learn how to use it.
It's not likely one will arrive at the optimum for his system in his room shooting blind. Without measuring, people will have no idea how much room for improvement there might be. There's simply no way to figure out the best combination of settings for an actual set of speakers and sub once placed in a real room without measuring and comparing different settings. I don't think I've seen him ever recommend doing this, usually eschewing measurements instead.
If you review Rythmik's own tutorial pozz posted above, you can see how different setups can give wildly different results and how these can be seen with measurements--as well as how they can be corrected with the DSP offered in even low-level AVRs.
And finally, you'll probably find agreement of 99% of the people here that EQ can be particularly helpful in the bass frequencies. None of his products offer this ability and I've never heard him recommend doing it.
As said above, none of this is meant to be a slight toward him or his company--he seems like a nice guy and I'm sure his products are outstanding. I was simply stating there's a whole world of possibilities when it comes to sub integration that are clearly not his area of expertise, so the advice he gives in this area isn't necessarily the final word on what's going to be best for most peoples' setups.
