With such a flat audioband response, it is no surprise that a 1kHz squarewave was reproduced with an excellently square shape - said John Atkinson in Stereophile review of Rotel RB 1080.
And just to check, I looked at several FR graphs of different power amps on Stereophile for comparison and they all look very similar.
Some amps, including Rotel, do exhibit couple of dBs roll off below 20hz, but are all fully flat from 20hz to 20khz.
How many passive speakers exist that are flat 0db down to 15hz that would suffer audibly form this slight roll off?
A 1kHz square at very low amplitude (as JA does) shows little about the low end. A 100Hz square will.
All the Rotels I have (probably about 6 or 8 of various vintages) plus every Rotel I've ever worked on, have (some would say sensibly) agressive LF roll-offs.
Just peruse any random Rotel schematic, do the math, calculate the F3s on the coupling RCs and the NFB loop RC values.
But to the funny part of the review you quoted, where JA blew the amplifier up on a 2R load. He says this:
The Rotel has sophisticated output protection, in addition to 6.3A fuses in the positive and negative voltage rails for each channel. Nevertheless, during the high-power testing, I blew the rail fuses when I was testing the amplifier's continuous output into 2 ohms. Even after I'd replaced these fuses, the amplifier would not turn on again—even after I'd let it cool down and had reset it with the front-panel Power button."
When he tested the RB-1080 in 2002, it only had 6.3A fuses and nothing to prevent overcurrent, overdrive, DC etc. Hardly sophisticated. The unit has a simple turn on delay/thermal function which merely shorts the inputs.
Here is the October 2007 revision where they upgraded the fuses to 8A, but still no
sophisticated protection...
Finally in the revision 5 of the RB-1080, in January 2008,
6 years after JA reviewed it, it gets some form of semi 'sophisticated' protection in the form of the ubiquitous UPC-1237HA protector IC and output relay. This IC can sense overcurrent, DC, short circuit, overdrive etc.
Bottom line? Don't listen to a thing reviewers say because, mostly they are regurgitating company provided BS.
And Rotel is a stand up company. Their product has always been decent, good value and solid as a rock.
