KxDx
My wife reminded me that my half of the money for the cruise is due next week. Dang, forgot about that.
So maybe April I can splurge on the X2.
I wil try that. I was worried that it was implying my sub was too *high* (I know that 21db boost in sub would be insane ). Will adjust the volume up and re-run.Increase the gain of the sub by 21db and then re run (just unplug the mic). Will work just fine!
Thanks again! Will test out this weekend.Arrow down: lower the volume, Arrow up: turn it up. I suggest to set the crossover at the sub at the maximum. The antimode has the default xover at 80hz, which can be adjusted (if you want to play with it) after the measurement, as well the delays (via browserinterface, you need the latest firmware as at 02/2023). But for that you should use REW, for comparing the different results.
@withoutsuit @sigbergaudio thank you both!! Yes, the sub was way too low and after I increased the volume, the optimization worked perfectly.
It sounds great (ok, maybe thats confirmation bias ), but jokes aside, the system sounds fuller and I can see the sub "play". I don't hear any boominess either. I suppose I can always increase sub level using the "Subwoofer Output Level" setting if I need a sub bump.
"Sound Profiles" is another option. Right now Sound Profile 1 has the default, and if I understand correctly I can either recalibrate on SP 2, and/or go SP 2 and then bump up the sub if needed, and so my SP 2 has a different sound profile. Did I understand that correctly?
Thanks again - you have been so helpful!
Mukund
correct. After the first measurement, alle three profiles contain the same. After that, you can adjust each preset alone or even do a new measurement for different profiles (e.g. 2.0 Preset 1 for listening at night without subwoofer and 2.1 with Subwoofer at Preset 2).@withoutsuit @sigbergaudio thank you both!! Yes, the sub was way too low and after I increased the volume, the optimization worked perfectly.
Mukund
Is that "Tone Control"? Looks like you can set the range, etc.The bass tilt feature works well too, as an alternative to increasing the sub. Then you'll get a lift across subs and speakers. As you may have seen from the manual you can also adjust where the tilt starts (from 80-500hz). Setting 3 or 4 and 1-2dB lift after calibration is a good starting point.
Yes, the Display is horrible and to configure it, a pain. Sometimes, I´m also lost in the menu options.Will give it a shot. The tiny, low-res screen is a pain to work with. I keep thinking I will get to the wrong menu and "undo" my settings!
Is the software available already?Arrow down: lower the volume, Arrow up: turn it up. I suggest to set the crossover at the sub at the maximum. The antimode has the default xover at 80hz, which can be adjusted (if you want to play with it) after the measurement, as well the delays (via browserinterface, you need the latest firmware as at 02/2023). But for that you should use REW, for comparing the different results.
There's a February 2023 update available.Is the software available already?
@sigbergaudio did the firmware improve the optimization over the earlier firmware?
and also, also very important, setting delays. Do you also have Spectogramm / Waterfall of the duo subs? Looks really smooth, already before the X2 smooting.Hm, no I don't think so, it just enabled me to have a 100hz crossover (first firmware was fixed to 80hz) and also to freely select the starting point of the bass tilt.
