RME ADI-2 Pro Has Arrived
watchnerd
Seattle Area, USA
"Ultra Fidelity PCM / DSD 768khz AD/DA Converter", 2/4 channels, balanced, headphone amp, preamp, USB, SPDIF, ADAT, AES.
The only thing it's missing is Thunderbolt and a mic preamp. Oh, I guess a remote if I was going to use it away from my desk.
It comes with a nice printed Bedienungsomereallylonggermanword. Nice and rare to have a paper manual these days. It even has English pages, too.
If anyone other than @amirm (because I know he'll vote yes) wants me to open it up to see what's inside, let me know and I'll take a screwdriver to it tomorrow and post board pics.
Blumlein 88
Surely you'll wait out the warranty before opening for board pics?
Interested in how well it functions for your needs.
I am envious though.
Blumlein 88
Remember the anniversary edition has a clear top. So there are some pics. Not the hyper level of detail we want, but a sneak preview.
Blumlein 88
A little more detail when you enlarge the image. Click on the image for a larger view.
tomelex
So called Midwest, USA
That's plenty of detail, keep her buttoned up is my vote.
Sal1950
The Chicago Crusher
Central Fl
If you can't open her up without boogering up the screw heads I'd take your tools away.
watchnerd
watchnerd
Seattle Area, USA
The only caveat is that they're likely metric or some Euro / German standard that doesn't match my tools.
I'll find out tomorrow morning...
Purité Audio
Industry Insider
Barrowmaster
London
I really like mine, I use it primarily to send a digital signal to the Dutch&Dutch 8Cs, I suppose for domestic users a remote would be useful.
Purité Audio
Industry Insider
Barrowmaster
London
Frank Hi yonks ago, the Metric Halo version was more expensive than the ‘Amarra’ version, just didn’t make sense economically I liked the MH though.
I remember trying to create an RIAA curve with it took me about three weeks!
BW Keith
Frank Dernie
Oxfordshire
BW Keith
Thanks. If you buy the plugin suite from MH RIAA is one of them. The limiting factor is getting the correct loading for the cartridge. MH offered a mod for those dedicating an input to a cartridge.
Now the Devialet has multiple loading options for cartridges, mind you I was told this week that with the new boards the cartridge input doesn't work at all and they are trying to fix the software so it does. I made the mistake of sending mine for update 4 weeks ago and suspect they won't send it back 'till the SW works which could be months based on previous experience.
The original D-Premier had a quieter phono stage than subsequent hardware updates if my memory isn't fooling me.
Currently using a Job pre/225 into the Epiligs and a classic push-pull valve amp with the horns.
watchnerd
watchnerd
Seattle Area, USA
No offense, but it baffles me as to why anyone is jumping on the Core Infinity board at this point when we don't even know all the features and it doesn't have a configurator.
Sticking with my vanilla 400 for now...
Purité Audio
Industry Insider
Barrowmaster
London
@ Frank I seem to remember that David Wright made me up a series of leads with different loading to experiment with , I use the Illusonic IAP for all phono,pre,dac,adc, EQ multi channel and everything else now.
Frank Dernie
Oxfordshire
I have an Original d'Atelier which gets free updates. I just sent it off when I got their email. I didn't know there was no configurator yet.
It is in every way daft to send it since I almost never stream anything having gone back to CD and LP, just thought I may as well have the update since they offered it for free.
I should know better, the dual D-Premier was fine for my use, all subsequent updates have actually been pointless for me :(
I bought my first D-Premier before the configurator existed btw, firmware was v2 or perhaps v3 at the time. You either used the default configuration, which was, after all, just like having any other amp, or if you wanted something specific Matthieu would write a file for you and email it to you to put on your SD card.
Frank Dernie
Oxfordshire
Do you sell the Illusonic?
Silly me, a quick look at your web site confirms that you do!
