Just curious, have you read the reviews of the 8801 and 8802 by hometheaterhifi.com? You can see that the 8802 has significantly lower THD in almost every measurement categories. The measured distortions were also much lower than the specified 0.005/0.008%.
Obviously even the 8801's were very low already, the 8802's were just lower. So if the 8805's are similarly low, but better in noise as Dr. Rich hinted, that's pretty, consider the only major change appeared to be from the LSI volume IC to the MSI one.
https://hometheaterhifi.com/reviews...ntz-av8801-11-2-surround-sound-processor-ssp/
https://hometheaterhifi.com/reviews/receiver-processor/processors/marantz-av8802-processor-review/
In the second linked review, Dr. Rich said the following about the updated HDAM circuitry:
"From an internal perspective, Secrets’ Dr. David Rich offered this analysis on the design of the AV8802:
“The AV8802 is similar in design to the AV8801 in the analog path but a significant improvement has been made to the output circuitry. The output circuitry is now a pair of fully discrete, fully complementary, current mode opamps per channel. The first discrete opamp is wired as a unity gain buffer (10 transistors) and interfaces between the Renesas R2A15220FP LSI and the RCA output jack. The output also goes to the positive output pin of the XLR (pin 2).
The other discrete opamp is wired as a unity gain inverter (14 transistors) and is connected from the output of the non-inverting buffer to the negative output pin of the XLR (pin 3). Current draw for the 26 discrete buffers is +/- 320mA.
The buffers are powered by a +/- 12V DC power supply. The unregulated rails for the discrete output buffers are produced by a separate transformer winding which would have had the function of supplying the power amp in an AVR. For the AVR the transformer winding would be at a much higher voltage.
RCA and XLR output anti-pop on power up muting function is performed by relays.
The signal to noise ratio of the AV8802 is improved over the AV8801 with the output stage redesign. The AV8801 output stage had a gain of two. The AV8802 output stage is now unity gain. The noise from the volume control block, which is the dominate noise source in the analog signal path, is not increased by the output stage in the AV8802. The signal at the output of the DAC, which is before the volume control, is doubled in the AV8802 to compensate for the gain reduction at the output."
and he has the following to say about the DAC change:
"The DAC is changed from a TI PCM1795 in the AV8801 to the AKM AK4490 in the AV8802. The worst case signal to noise declines from 120dB to 115dB but worst case distortion improves from 0.001% to 0.0006%. The distortion measurements are for a full scale signal at a data rate of 44.1k samples /sec. The AKM AK4490 supports DSD. The schematic shows data signal marked DSD coming from both chips associated with HDMI and USB."
The AV8805's service manual is downloadable. If you are interested in seeing the HDAM circuit, you can download it yourself as I don't feel comfortable posting the schematic diagram. From what I can see I don't think it is the bottleneck, but I also don't believe it would make any audible differences.
