ta240
- Joined
- Nov 7, 2019
- Messages
- 1,490
- Likes
- 2,965
It would seem the fear of saying you hear one thing and then measuring another would be that measurements would matter less. If you are shopping for a kidney dialysis machine then by all means only go off of measurements but if you listen to a speaker and hear one thing until the measurements tell you to listen for another, what is the benefit of the measurements? Because in the end all that truly matters is what is heard.......
If measurements tell me a speaker is totally flat, you want me to go and pontificate without that knowledge that what I heard was too bright? And then show the measurements indicating otherwise? To what end?
And when I watch Password on TV I pretend I don't know what the word is as I try to guess it along with the contestant. Yet I still end up shouting at the TV, "Their clue was 'First' and you guessed 'Second'? Obviously it the correct word was 'Last'". It just isn't possible to unknow something that fast.Note that when I do listening tests, I initially don't have the measurements in front of me. I use my laptop for listening and the files are elsewhere. I listen for a bit and give you the "stock impression." But then I look and re-evaluate what i thought. If test hypothesis with EQ development. I perform that testing blind if needed. I am fully connecting listening tests to measurements this way. This is the only sane way to give proper subjective data.
If an expert, trained listener can't hear a defect then does it matter that it is there? And even more importantly does it matter to the point of the bashing of the product that then ensues? Especially bashing where in an actual double blind test it would be unlikely that anyone would be able to pick out the product with the issue.
I kind of get the quest for technical perfection, but beyond the audible level it makes as much sense to me as being able to brag that your car can go 236 MPH. Sure it is an impressive engineering feat, but to do that takes a 3 mile long straight closed course, making it completely irrelevant. And in the real world it makes that car no better than one that can reach 200 MPH in the same time as the faster one.
The real world doesn't seem to be addressed enough in the reviews. I'm reminded of the Paradigm streamer that I bought because of the decent test on here that then made a popping sound between each song. There was no way to not hear that because the room was always quiet when it hit. I didn't need a measurement to tell me that was there and clearly no measurement said it was there. It was dismissed as just a small quirk from an otherwise great piece of equipment...
