Audio interfaces? Scenarios?
You really don't understand anechoic measurements of speakers, do you?
Please read post #1 in this thread carefully, then read the post #97 above from dominikz, then read Dr. Toole's book, then get back to us.
When you join a forum and immediately tell the people that they are doing the tests wrong, all the while demonstrating that you don't even understand the tests, well, you're gonna get pushback.
From the opening post in this thread:
"Measurements that you are about to see were performed using the Klippel Near-field Scanner (NFS). This is a robotic measurement system that analyzes the speaker all around and is able (using advanced mathematics and dual scan) to subtract room reflections (so where I measure it doesn't matter). It also measures the speaker at close distance ("near-field") which sharply reduces the impact of room noise. Both of these factors enable testing in ordinary rooms yet results that can be more accurate than an anechoic chamber. In a nutshell, the measurements show the actual sound coming out of the speaker independent of the room."
