Practical example of intersample peak greater than +6 dBFS
ayane
NorCal
I've mentioned it before here on this forum, but it's entirely possible to have music that has intersample peaks beyond +6 dBFS, or one whole bit. It was mentioned again later on this thread by @LTig.
Here is a 30-second excerpt of "Get Away" from the Electronic Soundtrack album Code Lyoko by the Subdigitals. The audio is from track 9 on the CD I've ripped myself, and the excerpt is from the 3:10 mark in the track. This track contains a lot of clipping, as is common in the genre and modern music, unfortunately, but it is of note because unlike other clipped tracks, this track contains not one but multiple intersample peaks that exceed +6 dBFS.
I have over 12,000 tracks in lossless format in my music collection, and a few of them hit a peak above +6 dBFS, while hundreds have peaks above +3 dBFS - the headroom in the Benchmark DAC3. I chose this particular example because it exemplifies the issue multiple times in the same track. I can post more examples if necessary.
I'm posting about this because I'm pretty disappointed with DAC digital filter design. It is this forum which has highlighted this problem, Many thanks to @amirm's measurements. Most DACs on the market don't even attenuate properly at the Nyquist frequency for 44.1 kHz audio, which comprises the entirety of CD digital audio and many, many more digital music files. On top of that, all of these intersample peaks that exceed 0 dBFS means that a digital filter needs headroom to properly oversample. Lots of headroom, not a wimpy 3 dB, but at least 6 dB (one whole bit), and ideally 8-9 dB to cover these fringe cases too. So, I'm calling out all the manufacturers who don't do any of this properly: this isn't rocket science, folks. It's 2020 and the math has been beaten to death. #MakeDACFiltersGreatAgain
LTig
Europe
On top of that, all of these intersample peaks that exceed 0 dBFS means that a digital filter needs headroom to properly oversample. Lots of headroom, not a wimpy 3 dB, but at least 6 dB or one whole bit, and ideally 8-9 dB to cover these fringe cases too. This isn't rocket science, folks. It's 2020 and the math has been beaten to death. #MakeDACFiltersGreatAgain
As workaround you could get the RME ADI-2 and run it with -8 dB volume (with fixed reference level) to get rid of intersample peaks. Or use a playback volume of -9 dB in the software player.
RayDunzl
Central Scrutinizer
Riverview FL
The recording engineers (pick another title) are creating the intersample-over problem.
LTig
Europe
I'm posting about this because I'm pretty disappointed with DAC digital filter design. [..] Most DACs on the market don't even attenuate properly at the nyquist frequency for 44.1 kHz audio, which comprises the entirety of CD digital audio and many, many more digital music files.
Full agreement. What happened to audio engineering?
q3cpma
France
Which is why using ITU-R BS.1770 replaygain with true peak should be compulsory for anyone with a little bit of knowledge. Thanks for highlighting this example, I wouldn't have thought that possible.
ayane
ayane
NorCal
I use ReplayGain within my player software, but only because I'm conscious of this problem and I also like having loudness normalized across albums.
Absolutely. Recording "engineers" haven't a damn clue what they're doing these days. I wish people would just use 32-bit floating point for recording and mixing instead of whatever god-awful nonsense goes on in studios these days. Worst examples are the wonderful music that Rick Rubin ruined. Another vote for ITU-R BS.1770 awareness from me.
ernestcarl
I was curious how your sample would look in JRiver in contrast to folky music I like.
I manually set my Reference Volume at 100% (actual playback SPL at listening position ~90 dB) for these samples. The vertical divisions on the analyzer graphic are scaled at ~2.5 dB per division (maybe, well, I'm not totally sure).
So I'm Growing Old on Magic Mountain by Father John Misty at 100% Volume
So I'm Growing Old on Magic Mountain by Father John Misty at 80% Volume
Get Away by Subdigitals at 100% Volume
Get Away by Subdigitals at 80% Volume
JRiver adds quite a bit of headroom for your particular track sample even at 100% volume, making it a bit more tolerable to listen to... Granted, I often listen to music at much lower volumes: my own program startup volume being at 40% with Loudness compensation enabled.
Max SPL Meter Reading at Listening Position (with volume correction):
In JRiver playing with simulated pseudo 5.1ch... -- or no actual center channel
LUFS EBU R128 analyzer plugin (with volume correction enabled)
LUFS EBU R128 analyzer plugin (without volume correction)
I would say both tracks at maximum volume are just about close to equally loud (at their loudest parts) to my ears -- or at least that was my perception. I only played (with all speakers ON) both tracks when volume correction was ON.
No way am I risking fatigue or damage playing anything with zero correction.
majingotan
Laguna, Philippines
I use UPnP to cast this track from my PC to my DAP, and while I didn't hear digital clipping at -0.0 dB o_O (probably my hearing is that bad but maybe the AK4499 DAC filters has more headroom), I was shocked on how squashed the dynamics are in this sample which is probably the most squashed track that ever reached my ears lol. Still baffled how I can't hear clipping or maybe I'm hearing it already but unaware of it other than no dynamic range whatsoever
bennetng
About your first link, John Siau is not the first one who talked about intersample overs:
https://www.audiosciencereview.com/...in-intersample-overs-please.11651/post-338342
About your second link, if you read the thread until the end you can see that I actually posted a link from John Siau and he already knew intersample overs above 6dB is possible.
https://www.audiosciencereview.com/...-best-audio-dac-in-the-world.8729/post-401550
Absolutely. Recording "engineers" don't have a fucking clue what they're doing these days. I wish people would just use 32-bit floating point for recording and mixing instead of whatever god-awful nonsense goes on in studios these days. Worst examples are the wonderful music that Rick Rubin ruined. Another vote for ITU-R BS.1770 awareness from me.
On end user's side, if ReplayGain/digital volume control/DACs with digital headroom eliminates audible distortion then it is a solved problem already, but the fact is doing so won't make Rick Rubin's stuff sounds better because most of the audible distortion is baked-in the audio data rather than clipped in the the playback chain, so it has very little to do with intersample overs.
On the production side, when the distortion is intentional, floating point, BS.1770 and whatever technology/standard you can name are not going to "solve" any problem.
https://www.audiosciencereview.com/...in-intersample-overs-please.11651/post-336772
There was a time when unintended digital clipping is caused by technical limitation and carelessness, but obviously unrelated to the typical loudness war people are talking about:
https://www.audiosciencereview.com/...in-intersample-overs-please.11651/post-336609
ernestcarl
Been doing some further comparisons and noticed that changing the mode from 5.1ch to 2.0ch stereo on my plugin meter changes the results a bit:
Get Away track sample to JRiver (DSP correction disabled) to Xonar U7 mII (1.13Vrms analog out) to miniDSP 2x4HD (2Vrms analog in & No DSP correction)
Even though it's peaking and clipping when sent to the U7 mII, the voltage difference gives the miniDSP still a bit of headroom if I wanted to add some EQ filters in that later stage.
I was surprised to see REW's full-range random pink noise fairing better...
... even though REW indicated peaks of up to +8.99 dBFS for this 0 dBFS generated noise, the loudness meter plugin only registers a +1 true peak... But the noisy signal is also so compressed that the dB RMS reading on miniDSP looks a little bit worse than the actual previous 'musical track' -- still not enough to reach 0dBFS due to voltage differences.
Now, with DSP correction enabled -- plus made a few a adjustments -- (in stereo mode) we aren't ever going to see clipping:
*If you're curious why I even bother with having/including a miniDSP in the audio chain (adding additional noise), well, it's mainly because I need it's optical input for another external player -- besides the main PC.
bennetng
In fact the Get Away clip from @ayane has a lower dBTP value than my chiptune example posted on another thread:
https://www.audiosciencereview.com/...ents/40-space-traveler-stage-3-bgm-zip.45777/
As you can see both clips don't exceed 6dBTP if I use foobar SoX plugin's default settings (95%) with 4x upsampling.
But wait... what if I set the passband to 99%?
What if I use SSRC?
That's why such a metric is unreliable and confusing. In case you wonder here are the white noise response of SoX's 90% vs 99%.
Now, if you read the datasheets of some DAC chips or AP measurements, which one is more similar to the actual response of these DACs?
AKM:
Cirrus Logic:
ESS:
BB:
All of them don't have a filter similar to 99%, more like 90%. The bottom line is whatever your true peak meter shows does not necessarily reflect what you DAC and anything before reaching the DAC (e.g. ASRC) do, and different true peak meters show different values, the errors can be higher than 2dB as shown above.
I've seen complains about using non-bandlimited test signals so I also have a post with a bandlimited test signal. Filters with typical steepness (as shown above) should not affect dBTP readings as the highest tone in the file is not higher than 18kHz, but different phase response will change the dBTP readings, feel free to play with it:
https://www.audiosciencereview.com/...ation-audible-intersample-clipping-test.2231/
Theriverlethe
It looks like you have Jriver’s clip protection enabled in every example. Check the bottom left.
ernestcarl
Ah, yes... True. The only other alternative which is 'flat line overlows' is still a form of 'hard' clip protection. I haven't looked into whether there is an 'overide' setting for the built-in protection, but from what I understand, the above 0dBFS peaks should still register in the meter.
Theriverlethe
You're right, I think the clip protection is applied last in the chain before dithering.
ernestcarl
What if I use SSRC?
AKM:
Cirrus Logic:
ESS:
BB:
Thanks for checking it. But yes, I have not disabled my 'room correction' which is just xo set for upmixing to MCH.
Here is it with everything set to stereo:
The total 'loudness integration is at -6 so that's what the OP was actually pointing at and not the true peak? I'm just guessing...
Duh... of course, you're probably right with what you showed in your tests.
Pluto
Harrow, UK
I think you might be wrong there. This is such an extreme example that, I suspect, has been deliberately (and quite cleverly) engineered to cause this extreme inter-sample excess (which, incidentally, I measured at about +4½dBTP). There is a totally unnatural extreme of energy between 15 and 20kHz and reducing this by quite a modest (totally inaudible) amount reduced the inter-sample peak to about +1dBTP.
I wouldn't be at all surprised if this “music” messed up more than a few tweeters through overheating, not to say completely ****ing up some people’s hearing for the rest of their lives.
KSTR
Berlin, Germany
With 20x (filterless) upsampling I can see a +6.6dBFS IS-Over at 0:10.488 but as @Pluto said this such a messed up music sample that the clipping (or worse, wrap-around like the YAMAHA CDX-595 CD player does) is irrelevant. The IS-overs that I tend to find in my collection of music seldom go beyond +1...+2dBFS which is handled by most DACs pretty well (either faithfully or with benign soft-clipping).
