POLL IS NOW CLOSED (thread remains open for analysis and comments)...
This is an updated follow-up poll to my September 2022 one. Was asked to see whether much has changed since then. Also deleted the active or passive options to simplify the poll.
As mentioned previously, the forum software limits the number of choices to 10. A final edit glitch also limited my ability to modify the responses without deleting the entire poll. So, the last couple of responses are out of order.
Thanks for your participation!
P.S.
Casting an intentionally inclusive net, wanted to include home theater and home theaters that are used for music listening. So, if you feel you are limiting your response, you likely should choose the Multiple systems option. For example, I have Amazon Echo speakers, a stereo system and a home theater. Which I listen to primarily is more a matter of convenience, so I fit the Multiple Systems case even though I barely use the home theater for video anymore.
If you are not sure how to answer, consider which equipment you use most. I do not want to edit the thread title at this point, but my hope is to help Amir with which equipment is most interesting to members.
P.S.
