Pioneer VSX-LX505 AVR Review
Rate this AVR:
    Votes: 162 65.9%
    Votes: 45 18.3%
    Votes: 34 13.8%
    Votes: 5 2.0%
TonyJZX
this is more about delivering whats on the spec sheet
would it be acceptable for a car company to advertise a 230hp sports car but only deliver 20hp after 35 secs because you dont need more under 'normal use'?
gvl
SoCal
Tesla does it, I haven’t heard too many complaints.
Martin
Cape Coral, FL
Isn’t this Pioneer exactly like the Onkyo that Amir tested previously, if you look at their inner live;View attachment 255698 not much differences to be seen. So also no surprise I guess there are issues measured with the power output. When reading the Onkyo thread you may find in real life the performance to be good. Perhaps the same may apply to its twin brother, or sister for that matter…
There’s a matching Integra, too.
Martin
TonyJZX
my guy, I do not hold up Tesla as the champion model of consumer rights as far as I hold up Elon as a model human being.
Put further if the Chinese did something like this how would we respond as opposed to a more 'established' Japanese company?
SoundsGood2Me
Again, Thank You Amirm!
I seem to say it more and more lately:
"You don't know how good you got it,
Till you experience Bad"
SoundsGood2Me
Chicago
Going to AXPONA soon
Maybe see you there?
TonyJZX
i think the pre processing stage has acceptable performance and in light of dirac then yeah... let us just say this is a good idea
one might just ditch all the processing and buy a pile of Chinese digital amps of say the sabaj a20 or smsl a300 and get more than acceptable performance?
certainly a market the chinese could plug... make us a 3/4/5/6 or more channel digital amp or chassis system where the unit does a good 75-100w? probably good enough with a subwoofer
HiroPro
Greetings ASR.
Lurker here...
Uh is it possible amirm's 4 ohm amps tests were done with the Speaker Impedance set to "6 ohms or above" in the speaker configuration settings?
System Setup --> Speaker --> Configuration --> Speaker Impdedance
Value can be "6 ohms or above" and "4ohms"
I think this might explain the low wattage output under 4 ohms load.
TonyJZX
but it does it under 8 ohm load as well...
if it does it under 4 ohms i can accept it
but also 8 ohms???
there's some amps that do warn that 8 ohms is preferered and that 6 ohm is the lowest (these are shit amps imo... i'm not saying this Pioneer is shit but amir would say "you have the graphs and you have eyes")
I tested both modes even though the "6 ohm" setting is always the right one. Never use the "4 ohm" setting in AVRs as that definitely cuts down power to pass UL heat testing.
HiroPro
Thanks for the quick reply!
And they both measured the same and had the output throttling and error reset to come back to full power?
I have this unit and it seems pretty good but all I've driven with it is Ascend CBM-320SEII with an easy 8-6 ohm load.
Fidji
@amirm - which one is worse - Denon 3800 or this engineering marvel?
I would Probably take Denon over Pioneer.
Krobar
I would say as a prepro the Pioneer is easily better. If using the internal amps probably Denon. Pioneer includes Dirac too which is usually a little better if you are happy to use a PC or Mac to do the initial calibration.
dlaloum
dlaloum
Greetings ASR.
Lurker here...
Doubt it - as it started at full power, and then cut back after 35s...
D
Deleted member 19122
Guest
Have one of these in running in 7.4 no issues at all running at mch loud levels.Typical level is -20 db.Bonus is that it is not a BBQ grill like a Denon! You can find these for 900 or so in the EU no way was I going to fork out twice as much for the Denon equivalent.Ive read of zero cases of this AVR shutting down in any of the dedicated online forums.
Robbo99999
Hang on, hang on, are we saying this power limited 35s timer is going to be activated/triggered during normal use, be it music listening or movies......I'm assuming it would be, but I wanted to check, I couldn't quite understand the specific instances where this would come into effect?
EDIT: I've read all the comments in the thread now. Ok, so it might not be a problem in normal use depending on what size your listening space is and what your efficiency of your speakers is......but either way we seem to agree that it doesn't meet the advertised specs - in which case it's a general miss for the product, unless you know your use case won't be specifically affected and you think the AVR is a good value deal for you usage. (I wasn't as severe in my voting on this product as most of you folks! DIRAC & ok SINAD & not extortionate pricing.)
EDIT #2: after doing a spot of AVR research & comparison here on ASR then this certainly isn't the best value option, but I won't give it the lowest rating, I'm close to giving it the lowest rating, but to me it doesn't quite deserve that.
EDIT #3: well if these AVR's are inexpensive in EU compared to other brands then that does sway in it's favour in some instances:
