The OM40 is/was a superb cartridge...
But this chart obfuscates due to it's scale - that single pixel rise above 15kHz is of import...
Sure - but that wasn't the spec. - and individual example variations, as well as loading variation, could easily push it to and outside of the specI’ve several copies that measure within 1dB. Not sure what’s mythical about that.
To be certain, you have to calculate the impact of the loading circuit, and deduct it from the F/R to determine the "pure" cantilever response (with minor contributions from things like eddy currents and other extraneous minor impacts!)I compared 6 VN5MR styli here, and the results show two consistent trends: https://audiosciencereview.com/forum/index.php?threads/mm-vs-mi-vs-mc.18636/post-1383126
The loading is much too high because it was adjusted to the CBS record, and I have plenty of evidence that the hump roughly between 8.5 and 17kHz is that particular record (#2), so if you can see past that and draw a straight line you can see the two trends, half with tails pointing up and half with tails pointing down. The one that I used as my first example in the library thread is one of the ones that points up, which measures within 1dB as JP notes. I have several of those. The ones pointing down are very consistent with each other and I don't see any evidence of any major variation other than the two trends, which is commendable.
I'm going to do another big VN5MR stylus comparison at some point now that I have things dialed down but if the difference isn't due to something like suspension trouble, stylus-cartridge fit (including not being pushed in all the way), or just me fucking up, then I would bet that the results for the ones pointing down are closer to a measurement previously reported on this thread by a member and in this review. Would that relate to a -2.5dB spec if there was any sort of production change? I find those numbers, from good companies, to usually be conservative anyways.
Yeah, but no one here is doing that.To be certain, you have to calculate the impact of the loading circuit, and deduct it from the F/R to determine the "pure" cantilever response (with minor contributions from things like eddy currents and other extraneous minor impacts!)
However, a rise at the top end generally would imply a higher effective mass - as the cantilever resonance is lower in frequency, pushing the high end response up...
I'll ask you about it in a week or so. I've been swamped trying to make sure the library thread wasn't a disaster at the start. Lots of stress making sure I got the first few measurements right. And a short-lived little emergency with the phono pre as well, lol.I have a spreadsheet that models the electrical performance and deducts it then plots the result...
Developed it with the help of LuckyDog on VinylEngine about 12 years ago... (LD disappeared a while back...)
I can share it... it's a bit rough - you need to import CSV's into the right place, and at the right resolution otherwise you have to reformat all the plots - but still it provides some interesting analysis
It's fiddly and a bit of a pain to use... thrown together more than 10 years ago - but it does expose the "raw" performanceI'll ask you about it in a week or so. I've been swamped trying to make sure the library thread wasn't a disaster at the start. Lots of stress making sure I got the first few measurements right. And a short-lived little emergency with the phono pre as well, lol.
I saw your additions in the library thread. I made some search tests to find the actual measurement posts and eg ”Shure” gives many hits. If you add the cartridge name as headline/the first line in bold, it will be easier to track down the actual measurement posts since it will be the first word in the search result for each post. I think it is a good idea to have it so. The thread will be long and searching for the actual measurements posts will be tricky if there is no first cartridge headlineI let you Measure them then before I buy!!
Have you seen LD lately? Last I saw him was on DIY audio. Would be nice to have him here, if he still is around.I have a spreadsheet that models the electrical performance and deducts it then plots the result...
Yes - he would be a valuable contributor here... but I have not seen him online in years (perhaps frequenting other forums...)Have you seen LD lately? Last I saw him was on DIY audio. Would be nice to have him here, if he still is around.
Now we are rolling. And, yes, now that we have an idea of what the thread will look like, I completely agree.I saw your additions in the library thread. I made some search tests to find the actual measurement posts and eg ”Shure” gives many hits. If you add the cartridge name as headline/the first line in bold, it will be easier to track down the actual measurement posts since it will be the first word in the search result for each post. I think it is a good idea to have it so. The thread will be long and searching for the actual measurements posts will be tricky if there is no first cartridge headline
