Phono Cartridge Response Measurement Script
JP
JP
Brookfield, CT
Around line 463, replace
Code:
#fig.legend(loc=3, bbox_to_anchor=(0.899, 0.11))
fig.legend(loc=3, bbox_to_anchor=(0.125, 0.11))
with
Code:
lines1, labels1 = ax1.get_legend_handles_labels()
lines2, labels2 = ax2.get_legend_handles_labels()
ax1.legend(lines1 + lines2, labels1 + labels2, loc=3)
The latter lets matplotlib auto-locate the legend at the bottom left. I've updated the code in the original post.
Thomas_A
Sweden
Test records are all over the place. My copy of the CA-TRS1007 suffers not only by poor x-talk, but has some weird noise in the left channel, which shows as wavy pattern for the L signal channel including distortion and an even more wavy pattern for the left silent channel (x-talk).
JP
JP
Brookfield, CT
File?
Thomas_A
Sweden
Thomas_A
Sweden
USER
Code:
with
Code:
Perfect. Thank you!
These were quick measures so crosstalk can be improved, but the former would never be helpful because of the test record. Each has its problems. I'll use style 3 for my CBS measurements for now.
I'm hoping to have a first go at a CBS to Clearaudio (hopefully JVC) EQ curve this weekend. They seem comparable to what you get difference wise. It'll be a start, anyways. I'll use it to compare future measurements and see how it does.
Thomas_A
Sweden
With the sweeps I get the following approximate crosstalk figures at 1 kHz:
CA-TRS1007 (new): -22/-25 dB
Denon XG7001 (mint): -28/-41 dB
QR2010 (not so good condition): -26/-34 dB
Same directions, perhaps I need to check with the 1 kHz Ortofon reference signal and adjust.
JP
JP
Brookfield, CT
7001 on my setup favors the left channel. Haven’t dug in to it yet.
Thomas_A
Sweden
My results for the Ortofon test record and 1 kHz tracks, things look good.
Raw RMS:
L->R 1: -33.4 dB
R->L 1: -32.4 dB
L->R 2: -32.6 dB
R->L 2: -32.9 dB
Filtered HP 100 Hz RMS:
L->R 1: -40.8 dB
R->L 1: -35.1 dB
L->R 2: -35.4 dB
R->L 2: -35.9 dB
JP
JP
Brookfield, CT
Thanks will check tomorrow. Did you check record centering?
Left channel of tracks 1 and 4 are modulated by a signal that cycles every 1.8s - double modulation, if you will. Is the record warped?
Thomas_A
Sweden
No, the record is quite flat. I bought it new and it was like that from start. The wavy pattern is the same in left channel whether it contains the signal or not. Crosstalk of the 1 kHz Ortofon test record is way lower.
JP
JP
Brookfield, CT
Highlighted section is 1.8s. I see it on @USER CA sweeps too but not nearly as pronounced. I supposedly have a few copies of this record on the way but don't currently have one here.
JP
JP
Brookfield, CT
Interesting - I can't filter it.
Code:
sos = signal.iirfilter(17,[10, 25000], rs=60, btype='band',
                            analog=False, ftype='cheby2', fs=Fs,
                            output='sos')
audio = signal.sosfiltfilt(sos,audio)
JP
JP
Brookfield, CT
It doesn't show up in track 3, but track 3 does show a ~1.25dB channel imbalance...
JP
JP
Brookfield, CT
Ya it's not modulated, it's an amplitude variation that repeats once per revolution. If you can duplicate it then I'd do a layback at 45 to see if the issue is in the grooves or not.
Thomas_A
Sweden
Yes it may be this stylus which has a .7-.8 dB imbalance measured by other means. I usually add .5-1 dB when playing. My previous stylus had around .3. That said I have an issue with my Muffsy DIY phono pre that I need to fix - the left ch drops out sometimes and there some poor contact that seems to be chassie-related. Don’t know ir that might be the problem, it is more an on-off effect.
It is however only the CA-TRS1007 record that shows the modulation in L channel. No other record.
JP
JP
Brookfield, CT
I'd do a layback at 33 and 45. If the pattern changes from 1.8s to 1.33s, then the source of the issue is the record, for whatever reason.
Silver lining - I've added an HP pre-filter to the script.
EDIT - similar cyclic patterns are prevalent in the distortion axis approx 400-900Hz and +2kHz typically. Have been curious about that for some time.
Thomas_A
Sweden
I’ll do some testing later on.
JP
JP
Brookfield, CT
Post number three will house the latest test code along with release notes and to-do/known issues list.
