dtaylo1066
- Joined
- Jan 12, 2019
- Messages
- 662
- Likes
- 830
A second harmonic generator strikes me as diametrically opposed (in the most rigorous sense) to everything this forum stands for.
And if we increase power to about 12.5w into 8ohm, we still see a nice monotonically decreasing harmonic distortion profile. THD is now about 0.016%
Just the opposite. It's an effects box - insert it between preamp and poweramp (like an EQ) and use it or not, depending on your mood, the recording, the weather, what ever. No need to buy flawed gear any longer to get this effect.A second harmonic generator strikes me as diametrically opposed (in the most rigorous sense) to everything this forum stands for.
What did you do with all the other tones in your music that are each creating that harmonic spray? You know, those bass tones with much higher amplitude than the violin. Now the harmonics of those bass tones are stomping over the violin tones, including its -20 dB second harmonic.Now note, H2 (and all) is (are) about 20dB greater here than that of the ACA tested. So the ACA is certainly not altering the waveform with an envelope to that degree; and of course all higher ones are proportionally much higher too. But the actual distortion probably does rest between a sinewave and this, closer to the sinewave.
Replace Q4 (FET) by a small signal bipolar transistor. Its much higher gain should help to reduce THD. Have to be careful though WRT stability.Can anyone look at this design and point to one or two major faults that, if fixed, would improve the performance?
But I don't see how it contributes to getting to a "straight wire with gain".
I'm not sure if we are in agreement; I think we are.What did you do with all the other tones in your music that are each creating that harmonic spray? You know, those bass tones with much higher amplitude than the violin. Now the harmonics of those bass tones are stomping over the violin tones, including its -20 dB second harmonic.
As opposed, perhaps, to a more modernistically inclined, LGBTQ (add any initials I may have overlooked) wire?
I think that isn't nearly woke enough...
Wow! This thread has really gone off the rails...
I accept full responsibility.
