That is very good news. If Magic ever approaches SugarCube quality there will be a good amount of people ready to jump ship.
It's a fantastic device but support from the manufacturer is sketchy.
MAGIC
This function gently lessens many of the small pops and clicks normally heard during vinyl playback. It consists of a click detector that monitors the music for outlier, transient sound events which are then flagged. An algorithm then determines whether the flagged event was likely noise or musical in nature - perhaps a trumpet or drum snare.
Once it has determined that the event was noise, a selective filter is engaged for around half a millisecond. So the Magic function is not processing 100% of the audio like a normal DSP filter, and actually may only be filtering a few seconds of audio per album side. This gentle method makes the record sound cleaner with fewer artifacts distractions, and doesn't have a processed sound at all since very little processing is actually done.
It will make your best records sound transcendent and some of the well worn ones will be much more listenable. It is recommended to be left on all the time.
Possible Settings:
Off (default)
On
It is the feature in the waxwing which minimises vinyl surface noise. You can turn it on or off.Pardon me getting up to speed, I know of Waxwing and Sugar Cube, but what is Magic?
12. MAGIC
Possible Settings:
Off (default)
On
How so? Shannon is continually developing the product, and always replies to questions within 1 or 2 days.It's a fantastic device but support from the manufacturer is sketchy.
It is a setting on product. Here are all possible settings: Link
Had to look up the Sugar Cube. The version that has the built in phono preamp sells for $2250 versus $499 for a Waxwing. Most of my records are "pop free" - I am careful and have a record cleaner that helps. I do have a few records that need help. Turning the Magic function on does not completely eliminate the pop or tick. It simply becomes less noticeable and far easier to ignore. This is good enough for me. From a value perspective, the Waxwing wins with ease - even if the Sugar Cube completely eliminates pops. The additional dollars would be better spent on improving your turntable/arm - if you did not already have a good table.Only on or off
how does that compare to the “gold standard”? The Sugar Cube
Pretty sure he was referring to the people at SweetVinyl, not Shannon.How so? Shannon is continually developing the product, and always replies to questions within 1 or 2 days.
There are a couple notable differences. The value of the differences is in the eye of the beholder.Who said SugarCube is the golden standard? It sells for several thousand dollars so it must be very good?
I think that lack of headroom in this case is a phantom problem. This forum, however never over complicates anything! That is sarcasm by the way.Wouldn’t it be just as simple as using a phono stage with lots of headroom and the waxwing as line in DSP box ..
just a suggestion for everyone that is complaining about the lack of headroom.![]()
