I have no idea. I'd never heard of the sugar cube** until yesterday.Only on or off
how does that compare to the “gold standard”? The Sugar Cube
**Except as something I can drop two of into a cup of tea.
Sorry - my mistake.I was taking about Sweetvinyl.
I think that lack of headroom in this case is a phantom problem. This forum, however never over complicates anything! That is sarcasm by the way.
Probablybut I quess if someone really wanted a phono stage with lots of headroom , this might be a interesting option. And just use the waxwing as DSP box
MM Pro MKII Moving Magnet Phono Stage by Michael Fidler
Precision RIAA MM phono stage by Michael Fidler with linear power supply, balanced outputs, mono switch and low-frequency crossfeedmichaelfidler.com
Passive RIAA network phonostages quickly run out of headroom at high frequency, as they throw it away into an attenuating network, greatly escalating the risk of overload when subjected to high-frequency transients and surface clicks, making the latter much more noticeable. The MM PRO, on the other hand, uses a fully active shunt-feedback equaliser that allows the maximum input voltage to increase from 82mV RMS to 400mV RMS at 10kHz and an eye-watering 800mV RMS at 20kHz, faithfully reproducing the most challenging discs.
Or this one with less features
SPARTAN 15 MKII Moving Magnet Phono Stage by Michael Fidler
Low noise phono moving magnet stage, with linear power supply, accurate RIAA equalisation, mono switch and low frequency crossfeedmichaelfidler.com
Who said SugarCube is the golden standard? It sells for several thousand dollars so it must be very good?
There are a couple notable differences. The value of the differences is in the eye of the beholder.
SugarCube offers much higher levels before clipping. Waxwing clipping is governed by amplification or attenuation of the signal prior to ADC. SugarCube advertises 7.7Vrms in on their least expensive model, and it goes up over 10Vrms from there. While headroom isn't unmanageable on the Waxwing, it's something that needs to be considered depending on cartridge and source material.
SugarCube offers USB out directly to a computer. You'll need to have some way of processing coax or optical with the Waxwing.
SweetVinyl has their own recording software. SugarCube (SC-1 Mini and its variants notwithstanding) can pull metadata from Discogs which I assume is incredibly useful when processing vinyl rips to the computer. If a person is digitizing a large collection I imagine this feature could be worth the price alone if it's implemented well.
We don't have any direct comparisons for the click removal yet. SugarCube click removal is variable and could presumably be adjusted to prevent some of the issues processing transients as noted in this thread.
Even if you don't consider the click removal, the Waxwing is still a very good product for its price with perfect RIAA and so much adjustability to the sound. The overall feature set is incredible value when click removal is added. If Shannon is able to further refine the Magic function it will basically make every other phono stage obsolete.
The sole interesting part of the SugarCube is its click removal software
Do we know that waxwing magic is not as good as sugarcube’s? I don’t know if any proper comparisons have been made.Excellent analysis, and imo summary and foreshadowing what might well happen
If Waxwing’s Magic did get closer to the competition … “will basically make every other phono stage obsolete” SugarCube sales would plummet
To my knowledge their only remaining unique feature would be the metadata. You’d think to maintain sales they’d have to slash their prices.
All other features are convenient automations, doable by anybody who can write code.
From my experience, my own gear and audio nuts I know, the difference between a $3000 table/arm and a $30,000 table/arm, is not very significant. If I were buying something new, I would catch a Denon 3000NE on sale and just be happy. That combo has a very adjustable higher mass arm- which I prefer, is direct drive, and doesn’t look like a DJ table- personal preference. Retail is $2500 and I would put a VM95SH on it and enjoy. You may want to spend more or less depending on budget and other factors.Question:
Does the choice of 'table and arm have a measurable or audible difference when properly used with the Waxwing? If so, which parameters are critical, and which not so much or at all? For example, low unweighted rumble, VTA, arm tracing error, and so on versus a cheap and cheerful entry level 'table and arm?
Examples would be the Stereophile A+ rating versus the B (or C if they have it) rating. Do we really need to spend this amount of money for esoteric stuff?
The Waxwing won’t fix turntable/arm deficiencies.
in general those with one at 3000 will consider it this way...From my experience, my own gear and audio nuts I know, the difference between a $3000 table/arm and a $30,000 table/arm, is not very significant.
I am speaking to my concept of “reality”. Pride of ownership of something expensive is more of an individual choice. Along the lines of the $30000 piece of equipment is not necessarily needed for proper playback. However, if you think it makes a difference and you can afford it and still keep your family fed, housed, and clothed - then get it, if it is needed for happiness.in general those with one at 3000 will consider it this way...
but those with those at 30000, rather the opposite....
What turntable is this? Seems like it has a vibrating transformer or something. Or an hum interference,? A 100hz notch filter will also filter the 100hz of the music.But that will be the case for me.
Due to the very high gain I need for my 310MC, I also pull up a 100Hz interferer:
I have now integrated a notch filter via the PEQ function:
You can see the filter result here:
You can simply hear an even better silence without the sound being negatively affected, which you can also recognize here with a pink noise test signal:
