One hell of a 12” woofer!
fpitas
Northern Virginia, USA
Not a ton of Xmax by modern standards, but it can take lots of power.
fpitas
Too much xmax can slow it down. Volume displacement is a healthy 7222c3 per linear stroke. Extension down to 20 hz is rare from a high power pro woofer.
Slow it down? You must know mathematics that I don't.
617
Somerville, MA
I wonder what the use case here is. Most pro driver mfrs don't make domestic style drivers with small size/low Fs/low efficiency/low power (relatively speaking) but once in a while you see one pop up which really could work at home, or even in an automotive setting. The Eminence LAB series are another one.
fpitas
I have to think heavy duty automotive. The low sensitivity is odd for a pro driver.
P
Positivevibrations
Theres tradeoffs that are made between long and short strokes. I think they found a great balance here. A good benchmark is maximum output at 30hz with reasonable distortion.
P
Positivevibrations
I’ll be using them for residential installs that require powerful bass down to 20hz in a small sealed cabinet.
617
Somerville, MA
I'm not a woofer motor expert, but I don't think there are many trade-offs with high end LF transducers these days, the motors tend to keep Bl pretty strong through the gap, and distortion simply isn't a psychoacoustic issue at LF. But everyone has preferences I guess.
Prana Ferox
NoVA, USA
I'm too lazy to model this but I'm not seeing what is impressive? 13.5mm xmax isn't that much for a sub, power handling isn't out of the ordinary but is only really useful if it translates to xMax, odd decision to make it an 8 ohm driver (and thus harder to pump big watts to), etc
E: just for instance, compare it to the Dayton Ultimax 12... I'm not seeing what this driver gets you that the Ultimax doesn't, and there are a lot more exotic drivers than the Dayton out there
617
Somerville, MA
Why these in particular? There are a lot of good options for sealed enclosures. Not to say these would be a bad choice, just curious why you're so excited. Do you prefer to go with pro sound providers?
P
Positivevibrations
If you guys know of something better please share. Especially at the $180 price point. But please share any 12” that’s better at any price.
P
Positivevibrations
They have a 4 ohm version as well of the same woofer. That Dayton has less than half the power handling. BL is almost half. Voice coil is only 2.5” instead of 4”. Also made in China instead of the UK.
P
Positivevibrations
Something should also be said for a company that’s been making drivers for over 100 years in the UK. And has 1400 employees. Might be able to afford better engineers than a generic Chinese brand.
617
Somerville, MA
The price I see is $330 and very likely made in China. If you want a good western-produced driver look at B&C and Eminence.
DVDdoug
It depends on what you mean by "better", and I'd want to model it in a box with WinISD (or similar).
I'm not an expert either but there seems to be a trade-off between sensitivity and Fs. Most pro woofers have more output (per Watt) and higher resonance. (I don't think Fs is as important in a small sealed box as it is an a ported box.)
P
Positivevibrations
I’m talking wholesale. I haven’t found anything from them that compares.
Regarding manufacturing facilities:
Manufacturing takes place at our own, ISO9000 and ISO14000-accredited, 30,000m2 facility where more than 1400 highly-trained employees share a singular commitment to quality.
Here, modern production lines enable Celestion to achieve exceptional consistency and productivity. In addition, the manufacturing facility replicates the Ipswich HQ test and listening facilities, incorporating its own hemi-anechoic chamber and acoustically neutral listening room, and industry-standard measurement equipment. This ensures the highest degree of accuracy from design inception right through to final manufacture.
P
Positivevibrations
Better is output, low end extension, power handling, volume displacement, quality control, distortion, brand reputation, price, etc.
BrokenEnglishGuy
Well, that output capacity in watts is meaningless if is not made for the lowest notes..
Fs
28.90Hz
