GabrielPhoto
- Joined
- Jul 14, 2020
- Messages
- 502
- Likes
- 286
Hi!
So I have been using the "legendary" JBL GX1200 for all my TR setups like Hovereze and Hoverback.
I am going to revamp my Hoverback setup and was looking into maybe getting some better woofers this time that are similar in weight to the barely 10lbs of the GX1200.
I thought the main specs to look at were RMS and xmax so I was looking at a few options mainly these ones:
ds18.com
ds18.com
Or maybe even this one as a last option as its heavier and I dont like the dual coils for wiring purposes:
ds18.com
But then someone told me this about the JBL compared to the first1 listed above (the SCS12S):
So based on that info above, it seems neither of the 3 I looked at will be a good choice.
Do you guys agree?
Thanks!
SELECT 12" Subwoofer 250 Watts Rms SVC 4-Ohm
Shop online DS18 SLC12S 12" SELECT Subwoofer 500 Watts 4-Ohm SVC audio subwoofers
IXS Shallow-Mount 12" Fiber Glass Subwoofer 800 Watts Rms SVC 4-Ohm
Shop online DS18 IXS12.4S Shallow 12" Subwoofer 1600 Watts 4-Ohm SVC audio subwoofers. FREE SHIPPING on all US Orders.
ZR 12" Subwoofer 750 Watts Rms DVC 2-Ohm
Shop online DS18 ZR12.2D 12" Subwoofer with 1500 Watts 2-Ohm DVC audio subwoofers
The JBL is slightly superior in almost every t/s parameter except for the Xmax so I wouldn’t expect any extra performance if any in fact.
Not sure how much you know about T/S parameters and I’m certainly no expert but these specs are the most important for HeZeBack applications imo.
BL - (motor force) weight of the ferrite magnet. Heavier usually means stronger and therefore better and more authoritative especially deep deep down low.
MMS - the weight of the cone itself.
Again heavier is better for HeZeBack and CD but doesn’t matter so much with CU.
Xmax - more is better but you have to have a strong BL to take full advantage of the extra travel.
FS - lower the better (resonant frequency)
RMS - both drivers are 250w but the JBLs Peak of 1000w is considered conservative.
Do you guys agree?
Thanks!
