Curvature
- Joined
- May 20, 2022
- Messages
- 1,335
- Likes
- 1,816
Genelec does the majority of their manufacturing in house.How does a small company like Genelec can innovate more than the big brands?
like Focal , Kef etc
Innovating is all they do. When they try to make home speakers they tend to falter.How does a small company like Genele can innovate more than the big brands?
So look at it this way. Ever tried getting 10 people to all agree on what restaurant to eat at? Much easier to get a group of 2-4 to agree than a larger group. Same thing with businessHow does a small company like Genelec can innovate more than the big brands?
like Focal , Kef
As it seems they are crossed lower, namely at 500 Hz:I'm wondering how those 4 domes work together. If I do a quick sim, it doesn't look too good. You definitely should not have this play over 1 kHz. But given the horn size, one would expect that it could play down to 800 Hz or so.
Here is a sim with 4 100mm drivers, about 25 cm apart
I'm not sure that even him can afford itWhen is Morten Lindberg going to replace his 7 X 8351B+W371 with 7 X 8381A
So, this is speaker nerd stuff but see the note for the crossover frequency: it's variable based on GLM calibration. Normally your crossover frequencies are fixed to create the smoothest DI for a given acoustical condition (size of woofers, horn characteristics, whatever). This system can actually adjust the crossover frequencies which will presumably alter the directivity response. This is an interesting point of flexibility.As it seems they are crossed lower, namely at 500 Hz:
Yeah, we have 2 crossover points of what is probably at least a 5-way system, so don't hold your breathAs it seems they are crossed lower, namely at 500 Hz:
Yes but probably those 2 fixed ones are the higher ones, thus the one of the coax and the other of the coax to the 4 lower mid drivers.Yeah, we have 2 crossover points of what is probably at least a 5-way system, so don't hold your breath![]()
Genelec's revenue was €43,9M in 2021, KEF's was €74M in 2021. Both aren't especially small or big. B&W is a lot bigger than both for example. And no innovation from KEF? Have you seen the LS60? KC62?How does a small company like Genelec can innovate more than the big brands?
Then why doesn't B&W innovate more ?Genelec's revenue was €43,9M in 2021, KEF's was €74M in 2021. Both aren't especially small or big. B&W is a lot bigger than both for example. And no innovation from KEF? Have you seen the LS60? KC62?
They can't even manage a flat speaker... what more would you expect?Then why doesn't B&W innovate more ?
B&W currently innovates more on stuff that sell well to their target audience like new membrane (diamond, "Continuum" etc) and and cabinet materials and constructions, something you also seem to desire.Then why doesn't B&W innovate more ?
They have a lot more R&D budgets
Not that important. But does it do bluetooth?OK, the most important specification of all ... how much does it cost?
I think that question is on everybody's mind. Don't lose your sleep because of it.Is there any chance they will upgrade the Ones with this compression coaxial driver instead of the existing one on 8361B
for example ?
if the max SPL of other drivers don't match with the max SPL of comp. driver, what's the point of using a compression driver?Is there any chance they will upgrade the Ones with this compression coaxial driver instead of the existing one on 8361B
for example ?
SPL is the only advantage of this driver over the "normal " one?if the max SPL of other drivers don't match with the max SPL of comp. driver, what's the point of using a compression driver?
