Dynamic - ability to easily swing from low spl to high spl, but mostly relating to bass response; more punchy. FR does not tell the whole picture as I am sure you are aware of.Can you describe PRaT and how that would translate to measurements ?
What do you mean with dynamics.
Arguably the dynamics are about the same and when looking at bass response the HD800S shows less compression than HD560S so arguably should have a better dynamic range in the lows.
PRaT - an imprecise term used to describe a combination of behaviors on a system level, including but not limited to, transient response. harmonic distortion, damping factor, slew rate, settle time and diaphragm control.
