Neumann KH 310A Review (Powered Monitor)
boxerfan88
The KH150 has are more linear and a much more narrow beam width than the KH310. So they should be less room dependent in their imaging. In my small room i struggle width the image of the 310, too. If you are in a bigger room width side walls far away, this is probably less problematic.
Out of curiosity, what's the distance between KH310 acoustic center to the side wall in your room?
Mine is ~69cm.
Honken
Scania
Stereo image is very stable and precise here, but I also have over 3m distance to the sidewalls. Mine are in a ~3m triangle with the 310s pointing slightly behind my listening position and with the woofers on the inside. It did take some tweaking to get the stereo image like I wanted it however, my previous speakers had a narrower beam width and they gave a precise stereo image as long as I was in the main listening position.
The 310s are not the loudest, but I have not heard any breakup either when they are crossed to subwoofers. I think that the test from Sound & Recording is worth a read if you wanna see some actual data on the loudness:
DJBonoBobo
any germ
Mine is ~69cm.
Something like that, i don't know exactly. My room looks like this:
dped90
NY
I like all my speakers to be 'boring', a speaker shouldn't impart any character upon the music, and that's my take as a Hi-fi user.
Likewise, as a Hi-Fi user, I would have to agree-as I'm sure would Pierre who built these speakers; see posts 15266, 15,276.
https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-764
But what is "voicing", where the crossover is tweaked to do what beyond its generally intended function? And I understand that voicing can also be defined as selecting electronics to impart a certain sonic character, such as preamp and/or DAC choices. If so, then doesn't such voicing betray the alleged goal of persuing onic neutrality?
Ze Frog
Yeah, pretty much. Thing is though we all like different things really. I like flat and boring as a baseline, then I'll add EQ/voicing if I feel necessary. Advantage of a totally neutral speaker is having that nice flat response to work from. I like flat a lot of the time, but I don't really hold myself to that's how it HAS to be all of the time. Some days or genres I want a bit more or less of something, a flat sounding speaker with good directivity effectively means you can tailor the sound far easier and more infinitely than swapping components all the time. It's a win win really.
Andreas007
Germany, Bavaria
I‘m confused. Suddenly this speaker is not good enough anymore?
Doesn‘t match with Amir‘s review and neither with the fact that many studios are using them as a reference.
Also look at Amir‘s conclusion with respect to bass capability when comparing 150 vs 310. 310 clearly wins.
To me it sounds like complaining on very high level.
JustCoolin‘
I often think that people who call flat speakers „boring“ don‘t really understand what „flat“ or „neutral“ in audio means, and are the victim of some weird, misinformed linguistic association simply based on the general meaning of the words „neutral“ or „flat“. :D
dped90
NY
Very useful reply, thanks.
Honken
Scania
It's as subjective as it gets, but these speakers have put an end to my upgraditis. They sound fantastic. I don't need them to go louder, even if that is a potential real issue (see the S&R review above).
My only complaint is that they get real warm and toasty when powered on, nice during the winter and less so in the summer. I would like the same speaker, but with more efficient amplification.
ReaderZ
How far away are the side walls are you considering to be "big/wide"? 15-20 ft? 30+?
DJBonoBobo
any germ
I never had a big room, so I don't know how many and which body part's lengths you'll need. Far enough for the reflections to become quiet and late enough.
trl
King of Mods
Iasi, RO
[...] One of these was a weak phantom center. But that problem was so obvious to me that I thought it couldn't be possible. And I moved around, I was listening not closer than 1.5 meters.
[...] But I can't stress enough how weird was the stereo image. They somehow gave me the same feeling of my AKG Q701, where you feel the left and right instead of a proper center. It was so obvious for us listening at them, that I can't believe it is not mentioned more. FYI, the other set of speakers revealed a great and precise stereo image in that room.
I had to let them go. If it wasn't for this, those speakers would make me very happy, and for a super-fair price. [...]
You need to toe-in the speakers to your listening point, especially if you intend to listen from 1,5 meters away, otherwise the stereo image will increase to the point where in between the speakers (so called "phantom speaker") you may hear pretty close to nothing. This is normal to speakers that have a rather narrow field, as per below picture from page no. 1 of this review thread:
Many of us consider this narrow field as being a PRO and not a CON, especially that horizontal reflections to the side walls will be greatly reduced this way, so room acoustics will be diminished and stereo separation increased. The fact that you're seeing this as a CON is due to the fact that you were listening to studio monitors from a closer distance (which seems normal for critical listening), but next time try to increase the distance between your listening point and the speakers or lower the distance between the speakers and see how it sounds. For larger audition rooms you may be better off with something else than studio monitors, perhaps with big full size floorstanding speakers.
P.S.: I love the stereo imaging of the AKG K701 & Q701 headphones, but sometimes I felt that it's too much, so I was using crossfeed plug-ins; you may also try such a plug-in for speakers as well, if you feel that the "phantom channel" needs revived.​
Roving
Hey, thanks for taking the time and for the informative reply. I would take the chane to ask (with an ounce of shame) how you read that graph..
I also really like my Q701, and I am happy to have them for some headphones check from time to time. I just take into account that they have this enhanced wideness (and I think objectively a weak phantom center), and I would say also a bit light below the 50 hz.
Chr1
Like most good monitors they can't do everything. At very close distances, nearfield, you are probably better off with KH80/120/150.
If you are looking something midfield the 310s are a better bet, I reckon. Particularly with subs. They are not made to go loud without them tbh.
You can bet that the woofers in the 80/120/150 will be distorting badly at volume without subs. More so than the 310 most likely.
trl
King of Mods
Iasi, RO
"A wide directivity speaker is typically thought of as one that maintains amplitude (sound pressure level, SPL) consistency between the on and off axis sound. A narrow directivity speaker is one where the on and off axis amplitudes are substantially different" as per https://acousticfrontiers.com/blogs/articles/speaker-directivity-off-axis-response-theory-and-measurement-techniques#:~:text=Directivity is the term used,on and off axis sound. In case of near field monitors we need to keep our ears in the center of the drivers otherwise some frequencies of the sound will propagate without us perceiving it at their full amplitude.
However, toeing-in the speakers is recommended for most speakers, even for full-range floorstanding, usually between 15 to 30 degrees for each speaker, to better match the audience in the room.​
Roving
Thanks again!
Roving
I start to be confused here, I have to say.
I navigated the forum a bit, and it seems that according to it, the world should be a sort of dystopic post-communism place, where each studio has either kh150, 310, or 420. Maybe some Genelecs are allowed, in your studio B.
But then I am told that:
-the kh310 (which is sold as a nearfield monitor), has to be far way, because that's how it is supposed to be. 3 meters away??? ok...but then..
- ..you can't push the kh310 too loud, because they push the lows too far for a sealed cabinet of that size
The Neumann page for the kh310 is full of misleading information then, I have too assume. Or, simply, they play on what the speaker shines at (not just that, I really enjoyed listening actual music on the kh310): measurements.
Roving
What studios? Famous studios using Neumann, afaik, have them for their multi-speaker setups. Because for sure they are pretty good for the purpose, and for a really good price. But those studios don't have Neumann as their main. And I am not saying they wouldn't be good enough to be mains. They are just not better as you may want to believe, and their "status" is not there with ATC & co.
I spent quite a few hours myself in an ambisonics room using 40+ KH120. They've been selected because they were really flat, and for a price that wouldn't kill you when you purchase 50 of them.
DJBonoBobo
any germ
Most of it is in the measurements. You can see exactly how loud they can play before bass distorts. For me, it is very loud. Much louder than i ever want. If you are in a bigger room with more distance, listen to highly dynamic, very bass heavy stuff and/or you don't have neighbours, YMMV.
Regarding the distance, from my experience i say they i would place them at least 1.5 meters away. I did not like them closer subjectively. This is still nearfield.
Roving
Thanks DJBonoBobo.
When I wrote my experience and my feelings after checking out the speakers, a lot of assumptions have been made on the reason why the speakers didn't perform well (if you believe on my judgement, of course). Thinking back to the experience, for sure I could have been more careful in creating the best listening scenario, but what I heard, for experience, is something beyond just being out of the sweet-spot. And I don't think speakers should be so dependent on all these factors. I remember the first time I listened to Genelecs, and some spatial music was played. I was sitting in a school pretty small room, with other people around, in a random spot, and I still remember how those Genelec showed me how a a pair of monitors can really create the acoustic illusion that a stereo field is. I don't think that if that day I was sitting 40 cm closer or further, or 50 cm left of right, it would have been any different.
Measurements. I believe in measurements. I like measurements. And I know that if you design something with measurements in mind, you can make choices to pass those measurements in the best way. But measurements are "discrete" representations of performances. It's a bit like passing a test with 100/100 because you studies the exact questions the test was about. And it's one of the easiest thing to achieve nowadays.
In my experience, the more commercial a product/brand is, the most it relies in showing measurements, linearity, wide frequency response, etc. They measure better then products considered to be the standard.
Then some of them (like Neumann) are actually good, but some of them are actual crap.
