Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,237
- Likes
- 5,477
Didn't know monitors are supposed to be fun
If your goal is to listen to the music rather than to your system, these monitors seem to be a pretty good choice.
This.Hello everyone!
I have been following this thread, and I was almost ready to buy the KH310s.
However, by listening to them again last week in Berlin, I noticed that these speakers don't go loud enough, and when I pushed them to a considerable volume, which for my ears was ok (not insane amount of loudness anyways), they start to distort and listening to the box of the speakers which is not a nice feeling.
Any thoughts on this? Anyone else had the same experience?
Thanks
They work much better tweeters-in IME. The stereo image makes much more sense.But I can't stress enough how weird was the stereo image. They somehow gave me the same feeling of my AKG Q701, where you feel the left and right instead of a proper center. It was so obvious for us listening at them, that I can't believe it is not mentioned more. FYI, the other set of speakers revealed a great and precise stereo image in that room.
I had to let them go. If it wasn't for this, those speakers would make me very happy, and for a super-fair price.
Nothing a good sub can't fix. It did for my O300Ds.The KH310 is super SPL limited. It doesn't show here really, but if you push it much at all it gets boxy and honky from the woofer having to do huge amounts of excursion. This is due to it being a very small sealed box asked to go very much lower than it would without massive EQ boosting. A sealed box of this size without a ton of LF shelving boost will not have substantial output below about 50hz.
This depends on the room. My O300Ds have the sharpest phantom center of all speakers I tried in my room, and the tweeters are outside.They work much better tweeters-in IME. The stereo image makes much more sense.
Yes, a sub is a huge help for sure. Dual subs even better.Nothing a good sub can't fix. It did for my O300Ds.
It's been my experience across multiple rooms, in makes more sense.This depends on the room. My O300Ds have the sharpest phantom center of all speakers I tried in my room, and the tweeters are outside.
Thanks for the answer. That makes sense to me, but just to clarify, I was locating the sound (at times) on the speakers and not in the stereo image with mid-high contents, while low content sounded great and faithful to the mix, right in the center or within the stereo image where it was supposed to be.The KH310 is super SPL limited. It doesn't show here really, but if you push it much at all it gets boxy and honky from the woofer having to do huge amounts of excursion. This is due to it being a very small sealed box asked to go very much lower than it would without massive EQ boosting. A sealed box of this size without a ton of LF shelving boost will not have substantial output below about 50hz.
I was interested in the kh310s because I thought it could be a great pair of "flat" nearfields that could prevent me from having to add one or two subs.Nothing a good sub can't fix. It did for my O300Ds.
I use three KH310 (L/C/R), dual decent subs, and love the result even when listening 2.0 - although my room is small, 3x 3.4m, so bass is problematic without DSP, and the sweet spot ain’t that wide.Yes, a sub is a huge help for sure. Dual subs even better.
I also wanted to say. For me they have a "wow" feeling. The lows are really there and tights. I didn't think the highs were problematic as I often read (even though, they were pretty crispy). Great mixes sound great, and they are revealing on bad mixes. I found them a bit soft on transients, if anything (like clicks, glitches, but also snares).
3 ways really need distance in my opinion, 2 ways less distance is needed for proper image while Coaxials image superb no matter the distance.This.
I was recently listening to the kh310a in a sort of A/B test with another set of speakers (a 2 way speaker which I am not gonna mention, it's not the point) and from the very beginning (I started listening to them pretty loud) I could "feel" the speakers so much.
Now, for sure I read in the past about the kh310, and I had some prejudices, good and bad ones, and we know this could affect our judgment and experience. One of these was a weak phantom center. But that problem was so obvious to me that I thought it couldn't be possible. And I moved around, I was listening not closer than 1.5 meters.
I wanted to mention this, after reading your comment, as unfortunately I didn't check if the problem would disappear at lower levels.
Hey,Out of curiosity, how were the KH310 positioned in your AB test?
Were the KH310 firing forward, or were they toed-in firing to a point behind the head?
My KH310 are toed-in firing at a point behind the head. The soundstage is pretty good, and the phantom center is locked in and doesn't wander. Having said that, when compared to KH150, the KH150 imaging is better I must say. (Using the camera analogy, the KH150 is pin sharp, whereas KH310 has a tiny bit of "soft focus".)
Maybe that's in the recordingHey,
toe in. They were sitting on stands with nothing around them (it wasn't the best way to A/B as we were replacing the speakers on the stands).
By the way, vocals, kick, snare, they were perfectly centered. It was in loud moments and for stuff like complex synths where my eyes would automatically look at one of the speakers, as they were kinda loosing any correlation and breaking the stereo image illusion.
Obviously I was playing tracks I know very well, or my own mixes, so I can at least exclude that. In fact, the other set of monitor didn't suffer from any of that.Maybe that's in the recording
Thank you,The KH150 has are more linear and a much more narrow beam width than the KH310. So they should be less room dependent in their imaging. In my small room i struggle width the image of the 310, too. If you are in a bigger room width side walls far away, this is probably less problematic.
