Yep, for sure.the question is if the mics are capable of registring the peaks without any mecanical compression
I use this Isemcon 7150, good to at least 140dB, to keep that from happening. https://www.isemcon.net/ashop/product_info.php?language=en&products_id=57
But I think even an ECM8000 might work.... depending on what the Lz Average is for the loud listening level.
My guess is the ECM8000 is good to at least 120-125dB peaks, so maybe good for around 95dB average SPL on the TriCycle track, before the mic would crap out.
Dunno, but wouldn't be hard to check the mic...just see if crest factor shrinks as volume is turned up...
but wait ! we get back to 99% of home systems will shrink the crest factor probably before the mic does....hells bells, can't even test a cheap mic
