Keith_W
AFAIK there are three ways we can measure room response for loudspeakers:
- Maximum Length Sequence (MLS), Exponential Sine Sweep (ESS) or single point sweep: The mic is set up at the listening position, and a single sweep is taken.
- Averaged: The mic is set up at various points around the listening position, multiple sweeps are taken, and the responses are averaged.
- Moving mic measurement (MMM): The mic is set up on a boom, and pink noise is played. The mic is then physically moved around the listening position whilst recording the result.
I have always done single point sweeps. This is as recommended by Uli Bruegemann, author of Acourate*. Then I came across this article advocating use of MMM which made the bold claim that there is no correlation between measured response and listening quality for a MLS. It also includes a quote from Floyd Toole who said "spatial averaging of speaker measurements is critical - single point measurements are erroneous and meaningless". This made me think that I should probably be doing MMM measurements. After all, repeated sweeps of my listening room have shown poor reproducibility due to minute differences in microphone placement.
Resources I have found online suggest that averaged sweeps are not done because of the time involved setting up the microphone and running multiple sine sweeps. The favoured approach is MMM.
So my question: should I (and most of us) be changing the way we measure in-room response? If MMM is so superior and so much faster, why aren't more of us doing it? Are there any disadvantages that I have overlooked?
* I tried looking for a source to suppose this claim but I was unable to. I might find it later, but for now you'll have to take my word for it
