KEF LS60 Room Correction Showdown: REW MMM vs. Wiim Ultra—A Data-Driven Analysis
For a quick "Dirac comparison" these are mine.
I revisited the Wiim RC measurements using a iPad Mini (borrowed from a friend) in combination with an Umik-1 microphone
What software did you use on the iPad? Thank you
There's also a subwoofer
That’s good, but the fact remains that you’re still asking the system to apply a boost. Your DAC or preamp will be asked to boost the signal to reach the curve.
I'd raise the gain of the subwoofer before running the Dirac measurements to avoid this.
Another day, another Dirac measurement on ASR, another 10db sub bass boost "beyond the curtains".
This is Dirac default suggestion. Non manual edit of the house curve was done.
Did you use 1/6 smoothing when you calculated the correction filters in REW? If so, this would produce incorrect filters. One should use Var smoothing (no smoothing below 100 Hz) when computing such filters, because REW needs to know the correct width (Q-value) to compute the correct filters.
As a novice at this, I never considered this. Thanks for pointing it out. I need to find time to run things again in REW and then also try out the WiiM room correction with the UMIK-1.
