Creating fir filters for seas kingroy mk3
Meander
Hi everyone, I have some thoughts/questions about creating filters for my new speakers. I built the kingroy mk3 kit by seas and want to use the fir capability of the hypex amps. Right now I use the dsp preset 1 provided by Seas. I used the mmm technique to measure a sphere around my listening position and had rew generate filters based on that measurement. I used var smoothing to avoid overcorrection in higher frequencies. Im quite happy with the results above ca. 200hz the deviation from my target curve is less than +-2 :D
Now about the FIR Filters, the Hypex dsp has 1500taps @93750hz on each output, OR 4500 on the Input. The plan is to use the hfd filters to make the speaker as flat as possible with measurements taken outside and then using the input eq to do some room correction with the available 9 biquads.
For the Crossover between Mid and Hi 1500taps are enough for steep 96db/oct Filters + Box Correction, but for the bass/mid crossover @ 215hz the taps are not sufficient, you have to go to at least 600hz with 48db/oct slope for the filter to be accurate down to the noise floor. I tried the high crossover but it didnt sound nice, crossover at 215hz sounds better to me.
4500 taps are enough for iir crossover lineariziation + box correction filters even on the bass @ 35hz
So its either iir crossovers + fir correction for a fully linear phase system (if you leave out the subsonic filter) with a delay of ca. 22ms
or
iir crossover for bass/mid and fir crossover + box correction for mid hi, so linear phase above ca. 250Hz and a delay of 8ms
Which configuration do you think would be preferable? My use case is listening to music, watching movies, djing, music production and mastering. For djing and music production with real instruments 10ms is the max delay i can tolerate.
You should expect more overall latency, so if movies are a must too you must find a way with them.
Rephase states the delay until the first impulse, which is half of the convolutionfilter. So is the "true delay" twice that number?
You will really know after you be done with them.
Filters on their own measure differently than stack on to each other.
I would expect more than twice, even way more depending the scheme.
Depending on your usage scenario the 25ms might be completely fine.
If you listen to music only there should be no problem that it starts 25ms late. For movies you usually can delay the video accordingly in the TV or AVR.
For gaming or playing live music even the 8ms might be a problem.
You have 3 presets on the amp. Why not try all variants by yourself? Ideally double blind.
One more point. Phase "issues" caused by IIR tend to be more audible in the lower frequency regions and the steeper the filter. So the audible thing to correct is only possible with the 4500 taps overall and there might be no gain in adjusting the higher frequencies only.
@Keith_W Have you had a chance to play with LinFIR? As it is currently free, I am wondering how it compares to Acourate for generating filters for an active 3-way speaker with all FIR processing.
The “flatten response in crossover region, apply crossover, export” approach I’ve seen in Acourate sure is appealing in its simplicity.
Also, is there any actual difference in say, an LR8 slope crossover made in LinFIR, Acourate, or Matlab? Or is the math the math and it’s just a difference in how easy the user interface gets you to an impulse file?
I haven't played with LinFIR, no. The problem was that I lent my interface to a friend for a couple of months. I just got it back, so I am able to take measurements again :) I'll probably give LinFIR a test drive at some point. But I have read LinFIR's documentation with interest. The author has a few interesting takes, for e.g. he thinks that a tap count above 16384 is unnecessary and overkill. Maybe he's right, I haven't tried decimating my tap count down to 16384 to see what would happen. And he's certainly not the only person who has expressed that opinion either, Glenn Dickie (one of the chief brains behind the DEQX) said the same thing to me.
An LR8 generated in Acourate, LinFIR, MatLab, should be the exact same LR8. At least, you would bloody hope it should be! I would be pretty concerned if it wasn't!
Generating an XO is an easy 1 step process in Acourate. As you can see, the standard minphase XO's are supported, as well as a couple of FIR only XO's. The "UB" class of XO's is proprietary to Acourate. It is unique in that it achieves a steep slope with minimal pre and post ringing. The trick is that it starts of shallow and then rolls off suddenly.
Thanks!
I thought I was replying to your DSP thread with this comment…
