OK I have a very strange result with my MMM measurement. Specifically, the tweeter.
I use the Acapella TW-1S tweeter. This is a plasma tweeter with integrated electronics with a volume control. The stupid thing about this tweeter is that the volume control is stepless, and has no markings. The ONLY way to set the volume accurately is with measurements. When I initially set up the speaker, I levelled the volume between the two tweeters with a test tone played by REW and an SPL meter.
TLDR:
- MMM shows diverging frequency response at the tweeter crossover point, with the LEFT speaker dB louder than the right. We will call the louder left tweeter the culprit tweeter. This is not seen on the SPS which says both are normal.
- Swapping the culprit left tweeter now makes the RIGHT tweeter louder. This confirms that the volume of the culprit tweeter has been set too loud.
- I performed SPS at LLP, MLP, and RLP. At MLP, the volume of tweeters is equal. At LLP the right (culprit) tweeter is slightly louder. At RLP the right (culprit) tweeter is much louder. This explains why the MMM shows a diverging tweeter response.
- I pulled out my SPL meter and measured the SPL at both tweeters at the mouth of the horn. Both tweeters measure exactly the same.
- I swapped the tweeters back, and reduced the volume of the left (culprit) tweeter using MMM. Now the MMM looks perfect, but the SPS shows that the culprit left tweeter is much lower in volume than the right.
- I wondered if it was a room issue, so I took spectros of both tweeters at the MLP with REW. The spectros look exactly the same.
The Evidence
I performed this measurement at the MLP:
The SPS was performed using Acourate's mic alignment method - Acourate plays a series of alternating high frequency clicks between left and right tweeter, and you move the mic until the amplitudes align exactly. It does not depend on the volume of the amplitude, only the timing. As you can see, with the mic dead center, the sweep shows that the tweeters are equal in volume. However, when I performed the MMM, it shows that the LEFT tweeter is louder by 3dB, implying that I did not set tweeter volume correctly.
So I performed this experiment - what happens if I swap the left tweeter for the right? This was the result:
Two MMM's performed at MLP. You can see that the louder tweeter, which was on the left, is now on the right. Conclusion: this is very strong evidence that the tweeter volume has been set incorrectly.
But this leaves the question: why does the SPS show that the volume of the tweeter is the same? So I performed another experiment. Using Acourate's mic alignment tool, I took a SPS dead center. Then I moved the mic 30 samples to the left and right, and took more SPS. This was the result:
I windowed the measurements very tightly to ensure that room influence plays minimal part in the result. As you can see, the SPS shows that the right channel is louder when the mic is anywhere but at dead center.
I swapped the tweeters back. Now what happens if we were to use the MMM to adjust the volume of the tweeter?
I adjusted the tweeters until they were the same with MMM. Then I did a SPS:
And as expected ... the Left tweeter is now softer.
So I was now wondering whether some kind of room acoustic issue is causing the volume mismatch. I cracked out REW and adjusted the tweeters back to the same volume:
And then looked at the Spectrogram:
Left
... and Right.
