Evgeniy
so I think there is no need to use high gain on the 887.
For some low-sensitivity headphones, especially planar HF, we need Hi (3rd in 789/887) gain.
Perhaps with 2V input. I'd doubt one would need third gain with balanced 4V XLR input.For some low-sensitivity headphones, especially planar HF, we need Hi (3rd in 789/887) gain.
789 is properly balanced. And 887 is just like 789.Is this proper balanced or is it just like the 789 ?
It's still properly balanced. Just not fully balanced. It takes the balance input and sums it. Then regenerate the differential signals. It's still properly balanced. In this case you get all the balanced design benefits, doubled voltage swing and separate channel.No it`s not, it is Single Ended, the balanced input is also converted to single ended.
Yeah. That's true. Like I said it's not fully balanced from input to output, but you do get all the benefits from balance and differential signalling.the circuit itself is not a balanced construction all the way through.
Timed off = auto turn off after no signal after a few hoursI just received 887, what is the difference between "timed off" and "bypass"?
I'm not sure I understand why. OPA1612 are dual-opamps, so one OPA1612 can take care of both hot wires coming from one XLR input. Couple of OPA1612 and four single opamp buffers seems fully balanced to me, but maybe I'm missing something here.the circuit itself is not a balanced construction all the way through.
As being discussed before, the balanced inputs are feeded to differential amplifiers with single ended output then goes through 2 gang pot. The signals are then converted again to differential signals, feeding 4 output channels.I'm not sure I understand why. OPA1612 are dual-opamps, so one OPA1612 can take care of both hot wires coming from one XLR input. Couple of OPA1612 and four single opamp buffers seems fully balanced to me, but maybe I'm missing something here.
It's much easier to implement this way than full balanced all the way through while needing to do balanced to single end conversion for single end output. Also it should be able to convert single end input to balanced output. Meaning there will be four different independent signal paths. It needs a lot of switches to realize the function, relays or multiple manual switches.And that's just because they couldn't find find 4-gangs pot or because these are quite expensive? Hmmm...I wasn't expecting this, although the amp itself if a real performer anyway.
