He states this pretty clearly in the review...could you recall the exact conditions, here with a streamer, of this jitter measurement? ...
indeed but it would be good to observe to make things clear and possibly point out the measurement in the same context as the previous measurements...in streamer..He states this pretty clearly in the review...
Agreed. If they fix them, I will revise the review conclusion.
It would be strange not to.I don't think there is actually... this is using ES9039Q2M, however there is no note in either manual about DPLL user settings;
JSmith
of course it is specified for jtest only on num input in the case of this new one....but typically it can be confusing, a jtest measurement is presented in streaming function on the old one..and not that on the new one...just that m9n aboutIt is barely better than the Mini Pro 3 that Amir recommended... I imagine that we have to consider the year of the test)
Matrix Audio Mini-i Pro 3 Review (Streamer & DAC)
This is a review and detailed measurements of the Matrix Audio Mini-i Pro 3 balanced DAC, streamer and headphone amplifier. It was kindly purchased new by a member and drop shipped to me for testing and costs US $1,025. The Pro 3 comes in the usual high quality casing from Matrix, weighing a...audiosciencereview.com
As I noted, I could not test the streaming part. But I am pretty sure the results will be similar as this is internal interference. It has nothing to do with the source as both USB and Toslink had the same issue.could you recall the exact conditions, here with a streamer, of this jitter measurement? ...
Yes.Amir, do you plan to retain the unit for a period of time in case there are updates to resolve the bugs? This checks off all the inputs I desire so I'm curious to know if/when the problems are addressed and to what degree. Thanks.
Even if it performed the same, what I would have expected from @MatrixAudio is a better support and a flawless product when it comes to features. Seems like we're not quite there yet.It is barely better than the Mini Pro 3 that Amir recommended... I imagine that we have to consider the year of the test)
C'mon @morillon .... Just read the review!sorry..I don't understand...why not do a jtest streaming test?
The Matrix guys are probably working 24/7 nowYes.
It's not always made available as an adjustable setting to the user though.I would expect that any DAC using sabre DACs to do the same.
Except now you have 2 devices instead of 1. I am a huge fan of these excellent all-in-one units.You can buy a 30$ SBC as a streamer and whatever DAC you want, less expansive, like SMSL C200, offering headphones amp.
