Just to be clear, is yours the SR7015?
If it is, keep in mind:
a) SINAD is not bad until pre out voltage is higher than about 1.5 V
b) The X3600H does not have preamp mode, so you can only get the >96 dB SINAD for the FL/FR channels by disconnecting the internal power amps.
c) Do you believe you can hear the difference between SINAD 96-100 dB and 75 dB? I don't think I can...
The SINAD of the other channels would not be better than the Marantz at pre out >1.5 V, but yes you will save a few hundred $, if you can find one.
The graphs below should allow you to compare the two, just note that the second graph is for the X3700H, for the X3600H, there is no preamp mode so you should use the use the green trace for the channels not disconnected to the internal amps, and the blue/red traces would be for the FL/FR channels for the X3600H, except also note that the X3600H for some reason, did measured a touch better than the X3700H, under the FL/FR, amps disconnected condition.
