I’m a bit confused about best matching practices between amp and speakers and I could use some sage advice: I put together a 2.0 system using the A30 and a pair of Elac DBR62’s. I now, after doing some more reading, understand that the A30 is considered underpowered for driving these speakers.My question is do I need to replace the A30 with something that has a higher wattage rating?
I’m using the system as a HT set up and to play vinyl records in a very small, open style, apartment living room/dining room. At 30 on the dial, the sound is already louder than I would be comfortable playing with the neighbors in mind, and at 26, sitting on my couch which is about 2M away from the speakers, I am already getting a better audio experience than I did with my old sound bar/sub set up.
I understand that having to crank up the volume with an underpowered amp is dangerous as you can overheat said amp and clip on the speakers which might lead to damage, but since I am no where near the 50 on the dial that I’ve read here as a red-line, can I live with this set-up as is? Thanks in advance for your advice!
