So, are you using them in nearfield? If so, how do you like them in that setup? Do you have a subwoofer as well?Driving Kef Q150 speakers
Thinking of picking up these KEFs next time they go on sale for my desktop setup.
@Malis - can you please test temperatures inside it during longer session on playing on PCB and elements ?
I have used it with 4 ohm, 6 ohm and 8 ohm speakers for several hours and the case from the outside has not been over 32 degrees Celsius (room temperature 23 degrees Celsius). I have loaned my amp to my local audiophiles who usually spend several thousands for amps so they can compare the audio quality. When I will get it back I can create a video of temperature measurements on case, on motherboard and the chip on board after several time spans and different loads.@Malis - can you please test temperatures inside it during longer session on playing on PCB and elements ?
I just wonder how the Loxjie identifies itself in your computers. Here is how it appears in mine. Its not connected to a Type C port actually a USB hub with my keyboard.
Same problem, maybe it's some solution right now ?No. Through the USB input PCM 88.2kHz, 176.4kHz, 352.8kHz and DSD are not supported according to Audirvana on my macbook pro. Even setting "DSD over PCM" gives no sound during playback.
The Loxjie A30 is based on the SMSL SA300. Therefore, the corresponding sampling rate for digital input has the same specifications. This is a design specification, so it is not a defective product.Same problem, maybe it's some solution right now ?
Depends on how big a space etcI ordered focal aria 906 with loxjie a30. did I do wrong? will loxjie's power be enough for focals? omg
